Need help
SOURCE: i have a turner plus 3 mic with 4 wires red,black,
i need to wire a turner +3 to my old midland 13-880b with a straight stereo plug(pusin)help
SOURCE: I need to know if it's possible to convert the
5 pin to 4 pin as follows, from the Cobra website.
1.->2 Audio
2.->1 Shield and common
3.->4 RX
4.->also goes to pin 1
5.->3 TX
Testimonial: "This is exactly what I needed. Thank you very much."
SOURCE: how do i wire a
hi the easiest solution i find is to keep the ptt pressed remove wires from connector ,then place connector in radio try two wires at a time you will finally get the transmit wires then all you need is the audio ,you can flick over to ssb to sort the audio hope this helps you goodluck
SOURCE: I have a 1990 cobra 148 GTL with 5 pin
The wiring is not likely to be the same.
The information on the radio is here:
http://www.cbtricks.com/radios/cobra/148gtl/index.htm
You will likely need to open up the mic to identify what your wires connect to to determine the correct oreintation. it is possible too you may find one of the models listed was used by Barjan and is nothing more than a rebranded microphone.
SOURCE: want to rewire a turner plus 3 mic to a 6 pin deitaforce
they make an adaptor, check ebay. i just got one for my d104 4pin to rci 6 pin. 5bucks free shipping.
