SOURCE: setting fax ringtone
get distinctive ring service from your phone company, that will get you a different number, on the same line, with different ringing pattern, my tel compnay charges $5 per month, then set the fax options to DRPD, and it will go directly to fax machine, while the phone calls on first number, will go to telepehone.....
SOURCE: OFF Button?
Sorry, there is no On/Off switch on that printer. When plugged in it will automatically go to Standby.
The Energy Saver can be set anywhere from 3 to 30 minutes.
The only way you can remove all power to it is to pull the plug from the wall outlet.
PLease do not "shoot the messenger" here.
You asked, and this is the answer, so I would appreciate a Fixya rating.
(Is it really a problem using the Energy Saver?)
SOURCE: i need a driver for canon laserbase MF5750 for Mac
Sorry to inform you but this printer was only designed for Windows, although there are drivers for all current versions of windows Canon does not support this printer on Macintosh.
Looks like you may have to try a different printer,
Chris
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size
At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
When [ENVELOPE] is selected:
Press <> or <> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
When [FREE SIZE] is selected:
Press <> or <> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>.
Use the numeric keys, or press <> or <> to specify vertical and horizontal sizes of the paper in millimeters (mm).
Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2")
Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
Specifying the Paper Type
[PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
Please vote if this helps ... Cheers :)
You can select from the following paper types:
Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER]
Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1
Transparency: [TRANSPARENCY]
Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1
Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
*2 A label that can be loaded in the cassette is a standard type (label standard card) only.
SOURCE: I need the manual for my Canon imageCLASS MF5750 All-IN-Ine Laser printer
type that in google.com and you should get your answer
