Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Sony Grand WEGA KF-60XBR800 Service Manual
Solution for and location of components to repair an error of the standby light blinking 6 times
Posted by BigDale on
gemagm
    Master:
  • Sony Master
  • 689 Answers
Lamp/Bulb A1601-753A (XL-2000U) .
http://www.shopjimmy.com/dlplamps?tv_brands_select=Sony&tv_models=Sony+KF-60XBR800
Posted on May 09, 2014
5 Related Answers
Anonymous
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
Anonymous
  • 4402 Answers
SOURCE: Sony Grand WEGA 50 or 60 inch, 6 blinking lights
6 blinks is a problem with the G1 board ..no DD 6v output. G1 board Sony part # is A-1060-177-A , prices are $90-$116 exchange core from several suppliers.
Posted on Jan 14, 2008
Anonymous
  • 51 Answers
SOURCE: Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Posted on Jul 10, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Posted on Dec 01, 2008
Anonymous
  • 556 Answers
SOURCE: replace bulb sony KF-60XBR800
When you are in front of tv grasp the right side of the front grill and pull it off, the lamp door is right behind it. Unscrew the cover and remove it, you will need the allen wrench provided with the new lamp to remove the old lamp just unscrew it and pull it out.
Posted on Sep 15, 2009
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
1helpful
I HAVE THE SONY GRAND WEGA MODEL# KF-50WE620 WHEN I HIT THE POWER BUTTON IT BLINKS GREEN 6 TIMES THEN RED 6 TIMES AND WILL CONTINUE TO BLINK RED 6 TIMES OVER AND OVER
A 6 blink error code on this model is letting you know that your G1 board is not putting out your +17 volt supply. You can inspect that circuit if you are experianced, or just swap out the board.
7helpful
2answers
My Sony Grand Wega picture went out & red stand by light flashes 3 times then pause & flashes 3 times again. What is wrong???
the reason the tv flashes its l.e.d is to tell you there is a major fault in the main circuit board (pcb) and needs to be fixed its not a fuse it not a reset problem its a dynamic fault that could be from a bad resistor to a downed capacitor if you have knowledge of these components then check them using a multimeter find the faulty parts and replace accordingly. but if you have no idea then it will need to go into the repair shop. a lot of our customers ask us if the unit (tv) etc after being fixed will be any good or should they buy a new one. a good tech will fix the unit and in most cases it will be tweeked and work better but always get a quote up front and hold them to it within $50.00
best of luck to you
if you need further advice please feel free to email us at [email protected]
merry christmas
please take the time to rank this advice if it helped you.
1helpful
My sony kf-60xbr800 keeps tirning off and on
If lamp has not been replaced in last 2-3 years then replace it, this tv turns off and on because of dying lamp.
Let me know if you see standby/power light flashing on tv front, this is an error code that shows some other problem instead of lamp.
Kf-60xbr800 indicator blinks 5 times
5 indicates lamp ballast failure p/n 1-468-510-15 . but thats not always correct. sometimes the tv doesn't detect it correctly and it's just the lamp XL-2000U p/n A-1601-753-A .
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
3helpful
2answers
Sony KF-50WE610 flahing red light (6 blinks)
Jeff, did you look at the Sony web site? They had a problem with 9 different TV models that were from 2003 and 2004, KF-42WE610, KF-50WE610, KF-60WE610 and 6 other models.
This is what it states: It haas come to our attention that a limited number of Grand WEGA rear projection TV's may exhibit warping to the lamp access door. In rare cases, some additional components may also become damaged as a result. and so on........
You probably have some components melted on the inside around the lamp. I have a 42 inch and I just replaced the lamp at Christmas and the door was melted shut. This is the second lamp that I have replaced, the door was starting to melt the first time. They never sent me anything about this problem, and as of today I am still trying to work something out with them. The repair shop who has it told me that it can't be repaired. The parts that are melted are not in stock and they don't make them anymore. They are supposed to get back with me and make me some kind of offer.
They will only fix this problem through March 31, 2009.
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
