Y-sus board
SOURCE: LG "NO PICTURE" , IF FIX WILL RECUR? ,DID LG FIX DESIGN FLAW 42PC3D
I had same problem - no picture, but sound worked - LG 42PC3d - was two months past warranty, but LG agreed to fix it as a warranty call. Service guy was out within a week to replace the Z SUS(?) board. Works fine now. This must be a typical problem, as LG did fix it, even though the warranty had expired. Good luck.
SOURCE: LG 50PX5D 50" plasma TV
I was just wondering if you were able to fix you lg 50px5d with the new board because i have the same problem.
SOURCE: LG 42PX4MVH PLASMA TV - Sound but no picture.
I have the same issue with my LG 42PC3DVA and I narrowed it down to the Y SUS board. After a little research there are a few items that are prone to go. The ceramic fuses (as you found), sometimes the capacitors on the Y SUS, Z SUS, and power supply go along with them You can tell because thy will be bulged at the top instead of flat. I replaced a few of my capacitors - they are only $0.89 each so it was MUCH cheaper than a board.
The other thing that is common on the Y SUS in particular are the FETs (also called MOSFET). They can be replaced if you are good with a soldering gun but they are static sensitive so be grounded. They are also a bit tricky to test so you may want to do some research on how to determine if this is the issue... or you can just replace the whole board.
SOURCE: PLASMA TV PROBLEM
The problem with this set, is defective YSUS board, to avoid future same problem, you must change the following boards: YSUS, ZSUS & Control.
Verify with LG if your serial Number is included within
lots production that were recalled by this design defect
Testimonial: "I'll try to contact LG dealers. Very hank you sir"
