Question about Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA
Haier upright freezer door will not stay shut
Will not cool and the door wont stay shut
2 Related Answers
douglas smith
  • 1462 Answers
SOURCE: new freezer has bad door seal
it often works to warm the seal with a hairdryer and reshape it
Posted on Nov 29, 2008
Ralph Cronenberg
  • 449 Answers
SOURCE: I recently bought a 20.5
no sounds like the door is not sealing
Posted on Sep 14, 2010
Haier troubleshooting
Does it have cooling coils in the back... or underneath... that might need to be cleaned and vacuumed out???. That is a common problem.. Another thing, check to see if the door is sealing properly.. The next suspect might be the temperature adjustment mechanism that you've been adjusting..
Aug 07, 2014 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
I have ice buildup in the lower right hand side of the freezer in the back behind the baskets
Haier are a bad brand, the unit has cooling fin frost up and will not allow air to pass through the cooling plates, defrost the unit for 2 days with door open and restart, if all good after that, keep doing it, if not, its lost gas and needs the bin. Quality items deliver lengthy trouble free operation, sorry but I put Haier in the Daewoo class, Kelvinator or Westinghouse next time, its worth that little extra. Regards Russ
Jun 11, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Buzzer is going off and the door wont close and everything is melting
The air leaks through the door making the things melting inside. Please fix the immediately. Usually the problem is on door seal or hinges .
Jan 09, 2011 | Haier 20.5 cu. ft. / 580 liter Upright...
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezer compressor turns on for a minute and then shuts off
ur overload chip is triggering, check r134 charge , or start relay, and condeser, otherwise ur compressor might be damage..
Mar 15, 2009 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Haier HUF138PA-Freezer not freezing
just bought one that a repair man had already been through with similar issues. i wanted it as a fridge so this was no problem. took me about 5 minutes to figure out the reason it wasn't freezing though...the switch at the top that turns the light on when you open it also turns on the fan when you close the door. the door however sits just a tad too low to fully engage the switch. put a piece of tape over the switch and let it cool for 24 hours. chances are this will solve your problem!
Jan 10, 2009 | Haier 20.5 cu. ft. / 580 liter Upright...
New freezer has bad door seal
Nov 29, 2008 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Haier 20.5 cu. ft. / 580 liter Upright Freezer HUF138PA Logo
74 people viewed this question
Top Haier Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Haier Freezer Expert? Answer questions, earn points and help others
