Question about Magic Chef CTF2125 Top Freezer Refrigerator
How many cubic ft is my kenmore 363.50227000?
How many cubic feet is a 2003 Sears Kenmore coldspot refrigerator please
The fresh food section is 15.4 cubic ft. and the freezer side is 10. cubic ft.
May 29, 2018 | Kenmore Refrigerators
What is the cubic feet of Kenmore refrigarator model #253.562824on and also need mearsurements of outside.
You seem to be missing a few digits in the model number. Sears Parts Direct lists 11 refrigerator models that start 253.562824. (The full models numbers have 2 extra characters, including 253.56282400 and 253.5628240N.) See http://www.searspartsdirect.com/model/search.html?q=253.562824 for the list of models.
Kenmore uses the 3rd digit after the decimal point to indicate the cubic footage of their refrigerators. With a 2 in that position, this model has a 22 cubic feet capacity (probably 21.6 or 22.1 cubic feet before rounding). Using the size of other models, the external dimensions will be between 30" W x 31-3/4" D x 69" H (the size of a 21 cu. ft. model) and 35-5/8" W x 28-1/4" D x 69-3/8" H (23 cu. ft. model). One current Frigidaire 22 cubic foot side by side model has the external dimensions: 33" W x 32" D x 69-7/8" H. (Note: the 253 in the model number indicates a product made by Frigidaire for the Kenmore line.) Unfortunately, I can't find the dimensions for any of 253.562824 models.
I hope this helps.
Aug 30, 2016 | Kenmore Refrigerators
How do you convert inches into cubic feet ?? ex.23.4 in., 22.7 in., 33,6 in. into cubic feet. ?
Easiest way is to first convert your inches to feet, then multiply:
23.4" is 1.95 feet
22.7" is 1.89 ft
33.6" is 2.8 ft
1.95 * 1.89 * 2.8 makes 10.32 cu ft.
Jun 13, 2016 | Kenmore Refrigerators
How many cubic ft. in a Kenmore microwave over stove model # 665-61612100
Just measure the inside dimensions of the unit in inches. Get the length, width and height then use this formula: (L x W x H)/12 = Cubic Feet
Feb 26, 2015 | Kenmore Microwave Ovens
What cu. ft washer in a model 110-82870120 top load kenmore washer.
you can find out by measuring the depth of the tub in inches. Measure the diameter of the tub at the opening where you put the clothes in. Multiply those 2 numbers. Then divide the figure by 144 which is a cubic foot in inches. That will Give you the cubic feet.
Example Depth of 23 inches and diameter of 21 inches. 23X21= 483/144 = 3.35 cu. ft.
Jan 16, 2011 | Kenmore 24032\24036 Top Load Washer
What is the cubic feet of this 20-25?
actually a bit bigger than 25 cubic feet
Total Volume 25.5 cu. ft. / 722 liter Fresh Food Volume 15.5 cu. ft. / 439 liter Freezer Volume 10 cu. ft. / 283 liter
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How many cubic feet are in the Kenmore Washer Model 110 80 series
The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Magic Chef CTF2125 Top Freezer Refrigerator Logo
70 people viewed this question
Top Magic Chef Refrigerators Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
