If you mean theres water leaking from the drive shaft of pump comming from motor ,Im not sure how you can see this as the motor pump is all in one housing on these , usually only the larger ones (1.5 hp +) have a seperate motor from the pump to allow viewing of this junction, Anyways on the all in one units , there not reparable , you'll need to replace unit , only the larger ones have replaceable seals , this should only be done by a qualified person that has experience with mechanicial seals as they dammage very easly durring improper install and adjusments and do tend to be costly
