Question about Adaptec Computers & Internet
Cannot render video capture stream
What settings do i need to render video capture stream
5 Related Answers
Anonymous
  • 1027 Answers
SOURCE: "cannot connect video smart tee to vmr filter" and "cannot render video capture pin to null filter"
You may be right - the drivers may be gone. Un-install the drivers for it using the Device Manager, and re-install from the CD.
Posted on Jun 18, 2008
Anonymous
SOURCE: ?Error? Cannot render audio capture stream
Download intervideo windvr and your problems are over!
Posted on Sep 08, 2008
iqbal965
SOURCE: Built in web cam problem
i have cam acer dvc-v6 but when i connect to pc, there is no pic out, is there any fix to solve my problem
Driver not registered with NetMeeting (possible black border)
please tell me what is that means ?
regards
iqbal
redline gokart
Posted on Sep 26, 2008
Anonymous
SOURCE: cannot render video capture pin to null filter
Right click desktop. Click properties. Click settings tab. Change your screen resolution and or color settings as appropiate. Good luck.
Posted on Jan 26, 2009
Anonymous
  • 854 Answers
SOURCE: it is a super digital capture tv card tuner from
I have similar problems before. But I upgraded my RMA module and it worked perfectly
Posted on Sep 16, 2009
Trying to capture video using AMCAP application and Pixelview PV-CX881P video capture card on Windows XP SP3. I see the video preview and hear the sound okay but when I try to capture the video, the...
your problem could be complex especially using XP did it work before? and why are you using on operating system that is 11 years expired. that could be your problem right there.
i posted a video below see if it helps good luck AMCap not capturing problem
Jan 30, 2018 | Prolink PixelView PlayTVpro Video Capture
Tv-tunner cannot render audio capture stream
What cable connections are you using? HDMI has to be enabled on you motherboard (high def. audio), if its S-Vidio you must run a seperate and dedicated audio cable from headphone jack to TV.
My first gues would be to right click your audio icon on your desktop toolbar and check your playback and recording settings, make sure the tuner card is the source, hope this helps!
Apr 03, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
WHEN I RECORD,IT SHOWS A 'NO AUDIO DEVICE
driver for ur video capture is not ok...Win7 lite version has not included all drivers....
if it works with XP then keep that rather use win7
Dec 18, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
cant render video capture pin to null filter
Nov 22, 2009 | Computers & Internet
Mikomi DC-7120 Webcam doesnt allow me to make a video
What this means is that your PC may bnot have a strong enough Video Card to perform a task called rendering which is a really just putting the video together in a video fromat that the PC can understand.
Some things you can try: Update your system add more RAM or visit Windows Update. Add a better graphics card this often are alos inexpensive these days and will most likely assist in your issue. In this case it is not the web cam but rather your PC that is having the issue putting the video together
Jan 17, 2009 | Computers & Internet
I cand recording the sound
can u hear sound ,,and if not you need to download the sound drivers to hear sound and to record sound and you can download it from this website
sound drivers ---> http://www.softwarepatch.com/utilities/ac97.html and http://www.softwarepatch.com/utilities/ac97.html
Jan 16, 2009 | LifeView Fly Video 3000 (701013821560)...
Don't understand error message
the meaning of the error "cant render " is that your system doesnt have the required video codec installed ...
so just install the required video format codec and then you will surely be able to capture the video ....
or may be some video rendering option is changed in the software from which you are trying to capture ...
so just have a check with this ...
if this is not the problem then if you install the video codec then it will surely solve your problem ...
thank you
bye
rate my solution
Aug 09, 2008 | Televison & Video
WEB CAM
do you have internet connection?how many months since your pc was reformated?if thats the problem,your system needs to be refrogram.
thakn you!!
May 13, 2008 | Computers & Internet
Feb 18, 2008 | Philips TV Tuner Video Capture PCI Card -...
Computers & Internet Logo
161 people viewed this question
Top Adaptec Computers & Internet Experts
John Dio
Level 1 Expert
Robert Graf
efs_perpends
efs_perpends
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
