Magic Chef MCM660A Microwave Oven Logo
A
Anonymous Posted on Apr 28, 2014
Sharp Microwave Does not Heat
All digital works, clock counts down but no rotation or heat
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 16, 2008
SOURCE: sharp digital microwave oven is not heating
I would most suspect a shorted high voltage rectifier diode, a bad connection on the FA terminal of the magnetron, or a bad magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Oct 13, 2008
SOURCE: Sanyo Microwave EM-G4775 - doesn't heat up......
It's probably a loose connection at the magnetron or a bad magnetron.
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers (in the US anyway) will send you the magnetron to do it yourself. If nothing else, you can save about $75US by taking it to the shop yourself.
Apparently you're in the UK, judging by the model number.
You can find Sanyo UK microwave owner's manuals here.
You can find Sanyo UK support, parts and authorized servicers here.
Anonymous
  • Posted on Jun 14, 2009
SOURCE: microwave has works but doesn't heat
Sounds like the Magnetron has stopped working. The Magnetron is is a specially designed powerful magnet that generates the high frequency microwave energy used to heat food.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 06, 2010
SOURCE: MCM1290A Microwave Oven: the timer counts down but it wont heat or the turn...
Probably a bad door switch. See this file.
Anonymous
  • 6771 Answers
  • Posted on Jan 27, 2011
SOURCE: Have a 22" microwave oven
There are a few things that will cause this problem, the high voltage diode, or the high voltage capacitor, and the magnetron are usually the culprits. I find that one or more of these parts will go making the cost to repair at least $100.00 and up.
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Sharp R-1460A Timer counts down very rapidily and no heat
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Sharp R-1870 Convection works, microwave doesnt heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytwyys
The clock works & counts down but the microwave won't heat
  • Disconnect the power for 30 seconds. After restoring power, do not set the clock.
  • If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Touch the clock pad. Enter in the correct time of day by touching the numbers in sequence. Touch the clock pad again.
1helpful
Microwave seems to work but doesn't heat up
HI, when the Magnetron becomes unstable, the microwave will not heat anything. simply replace the Magnetron. This device creates the heating action and it is damaged and not functional at this time.
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
heatman101
fggfd
2helpful
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Top Magic Chef Microwave Ovens Experts
Jerry Naidoo
NOEL
NOEL
vince
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
