Samson Resolv 65a Main / Stereo Speaker Logo
A
Anonymous Posted on Apr 28, 2014
Samson resolv 65a schematic - Samson Resolv 65a Main / Stereo Speaker
3 Related Answers
Anonymous
  • 56 Answers
  • Posted on Mar 01, 2008
SOURCE: samson 65a monitor speaker
If its not to big find a neostick or similar sintetic glue,piece of medicine bandage and black (if speaker is black) mat spray.First put some glue around the rip wait for 10 min and then put the bandage on it.After that again 10 min of waiting and new layer of glue on the bandage.Let it 24 hours for glue to dry an then respray it.If you can do it from the back side its better and repair is almost invisible.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Feb 02, 2010
SOURCE: my tweeters are blown on my Samson Resolve 65a
It might tell you on the back of the tweeter what rating they are. I should do a webserch for Samson spares and see what it comes up with.
barbu51
Jacques Marin
  • 566 Answers
  • Posted on Jun 14, 2010
SOURCE: Hi There the fuse just blew in one of my Samson
Hi there
To answer your question;
If it is not indicated near the fuse holder then look closely at the metal end caps of the fuse.
The value will be written on one of them,
It may look like 2A/250v for 2amps.
Hope this help
Cheers
Samson 65a: power good, speakers good , LEDs lit, no sound at all?
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
I need a transformer for my resolv 65a monitor
Are you an experienced tech? In most cases (unless there is a defect in manufacturing) transformers are not a common cause for failure. If it blows the fuse disconnect the secondaries and see if it still blows the fuse. If it does then the transformer is likely the cause, if the fuse doesn't blow then the problem is elsewhere. If you have 120vac at the primary and nothing(or very low) at the secondary(s) then the transformer could also be at fault. If you have done this already and narrowed it down to the transformer, sorry I cannot help. I used service Samson but no longer am able to get parts. Good luck!
1helpful
One of the woofers blew out. Where can I get a replacement?
Please contact by mail describe haw many oHm of subwoofer, active or passive it? may be we can help w/ replacement subwoofer sunrisenohchi@ hotmail.com
1helpful
65a Resolv studio monitors. The left one just blew out -- maybe. The blue LED stays dim, as though the monitor has been sleeping. When I power off the monitor, the speaker gives a loud pop, and the cone...
You are getting DC offset voltage on one of your amplifiers that is the reason the speaker pushes out and you might be hearing a humming noise too. Do not turn on the speakers till you get it fixed or else you would end up burning the speaker voice coil too.The dim blue LED is also an indication of a short circuit in the output stage.
Your left amplifier needs a output chip (IC ) replacement. You will need professional help to do that. Will cost you about 20$ plus service charges.
Tweeter is cutting in and out
need to open up speaker and check connections on tweeter. Check closely on tiny wires from magnet(voice coil) to paper cone
2answers
Hi there
Hope this help
Cheers
Tweeters will not put out sounds, they do not look blown.
You need to go inside and isolate the tweeters. Then with a 1.5volt battery apply the + to + etc for a second. If it pops it's working and the problem is in the crossover. If not it's dead!
My tweeters are blown on my Samson Resolve 65a monitors...anyone know what I should get (and where) to replace 'em?
1helpful
Samson Resolv 65a monitor repair
Its prob a dry solder joint problem.
http://www.gearslutz.com/board/low-end-theory/314545-samson-rubicon-r5a-problem.html
2helpful
3answers
Samson Resolv 65a Speaker - No Power!
There's a fuse input just underneith the mains input plug.A small screwdriver will open the small latch.You can get new fuses at Maplins.
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
