The text has ink missing from the center of each word all the way across
SOURCE: Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
SOURCE: Black Ink Cartridge
I just had this problem and seems there are two metal pieces where you place the ink. those metals have broken out of the plastic envelop and when I tried to put the ink (without looking) those metal parts broke into the cables that are in the back. Now I think my printer is broken.
Seems I tried to place the inc too hard into the printer but I really didn't press too hard. I think this is a manufacturing problem. It sucks!
SOURCE: hp officejet 4215 all in one printing very light black ink, new cartridge
you must change your printer settings to the default settings.
SOURCE: printer will not recognize new blk ink cartridge.
1) Please do not use RE-FILLED cartridges as they will clog the heads terribly.
2) Turn off printer, Remove all cartridges, Gently move the printer head to the RIGHT with short thrusts. It is not necessary to move it completely to the right hand home position just simply away from the obvious jam.
3) With a flashlight and tweezers try to locate paper jam in the print head track. Best to also blow out paper chafe with a weak air bulb. WARNING: Do not let your male friend or relative use extremely strong air pump for tires or air blower at corner gasoline station. (Do not purchase the cheapest paper the future)
4) Unplug the printer to allow it to completely re-initialize the internal electronics..... about 10 minutes should be fine.
5) Replace all cartridges.
6) Power up printer, then re-boot your computer with the activated printer connected, then print a test page. Everything should be fine.
