Question about Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531
My freezer seam to be running all the time - Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531
My upright freezer runs more than it is off
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Oct 03, 2017 | Frigidaire Freezer Refrigeration White...
3 beeps when in failure. makes ice for several hrs some times. compresser heat extreme. this unit is water cooled but h2o out put seams to low what should out put flow be?
First, 3 beeps means that the unit was in the freeze cycle too long and the 60 minutes back up timer kicked in and took over.
Now, for the water flow/ head pressure water cooled control.
You set the water flow for what ever it takes to achieve a head (High Side) pressure of 270 psi. the gallons per minute are of no matter. It's the pressure that you want to achieve and maintain.
If you fix the head pressure problem, the beeps should go away.
If you don't have a gage set, then measure the temp of the exiting water from the condenser. It should be in the 104 to 115 degree range. Any lower or higher, and the unit will not run like it was designed to do.
Hope this knocks it out for you.
Oct 23, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Suction line on walkin freezer is sweating from condensor to evaporator above ceiling
The insulation wrap around it needs to be replaced. Thats the black foam stuff around the pipe.
When it gets old it loses its insulation quality and the the humidity condenses on the pipe.
Wrap it well in new insulation ensuring that all seams and openings are taped, and every square inch of pipe is wraped, but not to tightly. (Compressed insulation lowers efficiency)
Aug 26, 2009 | Freezers
I have a Maytag MSD2142ARW side by side and it has been steadily gettingwarmer on the fridge side. The freezer appears to be cooling fine and I know the fridge gets its cool from the freezer side. The fan...
HI, your Temperature Control Module has failed. it controls the air flow and vent(damper) action. replacing the temp control mod will fix this issue you are having at this time.
Jun 10, 2009 | Maytag Freezers
Kenmore Chest Freezer C675-18012-1G purchased april 2000
Average freezers last for several years, usually 10 or more. The compressor should not run all of the time, maybe less than 10 to 20 percent of the time if it is working properly. Not sure what you mean by the bipass, some freezer have a manual defrost, and in this mode it will not cool. Insure the location where you have the freezer allows for ample air circulation, sometimes folks put them in little spaces that prevent air circulation to the condensing/compressor unit and they overheat and do not work well and fail very quickly.
Nov 27, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Freezer runs all the time
I don't have enough information. Use a freezer thermometer and check the temp. If below 0 probably a bad thermostat. Sides getting hot is normal. Thats how it gets rid of the heat from inside. In the summer a freezer can run over 80% of the time. Again this is normal. Another thing to check is the gasket around the door. See if it is worn or torn and is sealing properly. If there are condensor coils under neath clean them check to see if the fan under there is working when compressor is running. (Not all freezers have coils underneath. Some have them in back, Smaller units just use the side of the cabinet.)
Jun 26, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Indest Fridge Freezer
Possibly something was spilled and it got to the door gasket. Clean the door gasket area with warm soapy water. In the door there is nothing critical to the system operation that should cause the condition you have.
May 17, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
Feb 11, 2008 | Freezers
Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531 Logo
85 people viewed this question
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
