Question about Dirt Devil Breeze Bagged Upright
Why does the belt keeps comming off - Dirt Devil Breeze Bagged Upright
Dirt Devil
  • Official Brand Answer
  • 69 Answers
Hello! If your belt keeps coming off, this usually means the belt is stretched and needs to be replaced. The Dirt Devil Breeze takes a Dirt Devil style 4 belt. Follow the link below to purchase the replacement belt. Hope this helps!
Style 4
Posted on Oct 28, 2014
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
How to stop main belt from comming off motor shaft on a windtunnel model u6634-900
Need to replace both drive and roller brush belt. Can't just replace one even if the other is fairly new.
Jun 21, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Why is the new belt on my dirt devil featherlite repeatedly slipping off? Everything else on it works fine and the b elt is the correct size.
Hello! There is no other part that goes on the motor shaft after the belt is put on. The tension of the belt keeps the belt from slipping off. If you have a brand new belt that keeps slipping off you may not have the correct belt for the vacuum. Be sure you replace with a genuine Dirt Devil belt and the specified belt style for your particular unit. Hope this helps! If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Apr 28, 2014 | Dirt Devil Vacuums
Belt keeps coming off
Hi There,
Most likely 1 of 3 problems.
1. The belt is stretched and so is just slipping off
Solution change the belt
2. THe brush roller has siezed bearings so brush cant turn properly so belt is slipping off the shaft.
Solution - check see if roller turns easily by hand if not change the bearings.
3. THe motor has twisted in its body due to cracked housing or worn rubber seats.
Solution- Depending on your skill and age of vacuum replace the housing or the vacuum.
If you need parts for your vacuum visit www.vacuumspot.com.au
May 13, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Hoover U6439: Belt keeps slipping off
The belt is stretched and you simply just need to replace it. You can get the belts you need for this model here:
http://www.vacbelts.com/hoover-self-propelled-windtunnel-belt.htm
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Drive belt ; whirlewind litespeed.
There is nothing but the motor shaft. The belt rides on the shaft and around the brush assembly on the other end. The belts fail if the brush assembly gets jammed, for example from a rug ot debris. If this occurs you should immediately turn off the unit,unplug the power cord, and clear the jam. Also occasionally cleaning the brush and being sure the bearings on each end turn freely will help prolong belt life. The brush assemblies also look to be available. [email protected]
Jan 25, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Belt keeps coming off even though I replaced it with a new one. It will not stay on keeps throwing them off.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=739734
Belt (by 2 users)
Posted by lynndian on Jul 04, 2008Belt keeps coming off even though I replaced it with a new one. It will not stay on keeps throwing them off.
I have a fathom vacuum and replaced with new brush roller and belt
but it keeps kicking belt off the spindle there is nothing to hold it on
Is there suppose to be didn’t see any broken pieces inside it. Anita
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 WindTunnel. On the Hoover and probable on the Fantom it sounds to me like you have a broken motor mount and it needs replacing on both machines. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 04, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuum keeps burning up belts
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=565438
Generic problem for all Vacuums
Posted by campoclan on May 02, 2008
Vacuum keeps burning up belts Comment by campoclan, posted on May 02, 2008
I have a Kirby Sentra and have had problems since I bought it a few years ago with burning up belts. I go through at least two a month. What is wrong with it? I keep the roller clean each time I vacuum.
Some Kirby vacuum in the brushroll have bushings and some have bearings and the bushing bind up and do not spin properly and I suggest to replace your brushroll with a genuine Kirby belts and brushroll of which would work the best for you performance wise. A suggested belt change depending on carpet can be every 3 to 4 months or 4 to 6 months and the brushroll when needed, some carpets are ******* the belts and they do require change more frequently. The rest should be fine. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Keep replacing belt that drives brusher but keeps breaking. When feel belt driver rod it is superheated.....could it be melting into the stretched belt causing it to weaken?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559226
Posted by andy78billy on Apr 30, 2008
Depending on the brand name and model # it is my opinion that it is not the belt, it may be that your brushroll is bound up with thread, hair, dirt, etc., and is not spinning well – place the brushroll on end and try to spin it, if it does not spin freely, then you are bound up, try to clean it up and lubricate by using one drop of oil and then wipe off the excess, you don’t want the oil to hit your carpet, if that does not work replace the brush and the new belt, am average flat belt change is every 4 to 6 months – also you may have the wrong size belt of which would cause the to burn up fast. Always use the genuine vacuum belts when replacing.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
How do you take apart a hoover brush n wash to replace the belt
How do you take apart?
How do you take apart a Hoover brush n wash to replace the belt?
On a Hoover brushroll there are 2 types, wood and metal, and the metal can be washed with water and the wood should only be wiped off, knowing the name brand of the vacuum most of the vacuums the belt change is done by removing the bottom plate and exposing the belt, 1st hook the new belt around the brushroll and then use a screwdriver or similar with a bent hook on the end and then pull or hook the belt on to the motor pulley and then track the belt to make sure the belt stays on, then re-install the bottom plate and turn the vacuum on to test to see id the belt was installed correctly. The other is to look for 2 or 4 screws on the bottom and then remove the top cover and follow the instruction listed above without the bottom plate. A belt change should be done every 4 to 6 months on regular basics and to keep the belts in the refrigerator to keep them fresh.
8 a.m. - 7 p.m. EST
www.A-1Vacuum.com 1-800-657-1874
Apr 21, 2008 | Vacuums
Dirt Devil Breeze Bagged Upright Logo
214 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
