Question about Transcend T.sonic 610 MP3 Player
INITIALIZING AND NOT GOING FURTHER
Posted by sreek on
  • ketank Nov 10, 2007
    Hi
    I bought a T.Sonic 610 (2GB) about a month ago.
    It just power on - starts with
    T.Sonic Family Initialising........... and nothing happens later it stays has it is. Please let me know how to fix this problem.
Anonymous
The player's firmware has crashed.
did you format it under windows explorer? O_o, yup you probably did ^^
anyway, just pullout that driver cd that came with the player, install the recovery software from there, run it and it will get fixed
Posted on Dec 31, 2007
MY PRINTER REMAINS ON INITIALIZING
Is this an HP 500 or 600 ?
the fuser is going bad it will need replacing.
Mar 06, 2013 | Fargo HDP5000 Thermal Printer
My HP LaserJet P2055dn just writes initializing and doesn't print. If i restart it just makes some boot up noice and then writes initializing on the LCD
My HP LaserJet P2055dn just writes initializing and doesn't print. If i restart it just makes some boot up noice and then writes initializing on the LCD so what can i do please help me?
Aug 14, 2011 | Office Equipment & Supplies
Initializing wong go further
I think the problem is the operating system on your system, i think it is corrupt, i will advice you reinstall the operating system on your system, if you are unable to reinstall the operating system, it means the hard drive is bad, you will need to replace the hard drive.
Take care.
Nov 19, 2010 | Visual Land VNet VL760 Netbook
My player stays on the opal initializing screen
ele nao ta ligando so assim initializing
Jun 26, 2010 | RCA M4204 MP3 Player
IT GOES TO THE INITIALIZING SCREEN THEN GOES TO A...
  1. it wont trun on it goes 2 the initializing screen
May 21, 2010 | RCA M4204 MP3 Player
Printer runs the self test and then initializing and then stops at "initializing, please wait" and goes no further. has new firmware and good memory???
I have had this problem several times and it was always caused by bad inkcartridges. Try starting up the printer without all cartridges. When printer tells you to place the cartridges put them in and see if you get an error. The cartridge witch causes the error is the "bad guy".
Jan 27, 2010 | HP DesignJet 1050c InkJet Printer
XEROX Phaser 8560MFP won't go past "initializing?"
Disconnect the data cable between the Electronics Module and the Printhead to see if Power On Self Test (POST) gets further, to the point where it displays a system failure code relating to the Printhead being disconnected. If so, replace defective printhead.
Dec 12, 2009 | Xerox Phaser 8560MFP Laser Printer
Can't get past initializing
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jan 28, 2009 | SanDisk Sansa Clip MP3 Player
Cannot computer to star
Try resetting your BIOS and remove any USB hard ware
Nov 22, 2008 | Gigabyte Computers & Internet
HP G85 is stuck on "Initializing"
Sounds like your main board has gone out on this unit. We can sell you a replacment board for $45 if interested. Its not too terribly hard to install.
Inkworks
866-381-0541
Nov 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Transcend T.sonic 610 MP3 Player Logo
79 people viewed this question
Top Transcend Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
