Question about Bulova Watch
How do I change batteries on a M.Z. Berger AW 213 watch
Need to change batteries
Matthew Sweger
    New Friend:
I know it's been a while since you posted this question, but I just had to do this with mine after it was lost in a drawer for a few years, and I had no luck googling so I had to figure it out for myself.
First, you have to remove the band, but you only need to do this on one end, not both. I did this by twisting the watch body around while holding the cloth/leather portion of the band still, letting the elastic part twist around with the watch body. Then, just use a fingernail to pull on the ridges on one end of one of the pins that are holding the band on; both ends are spring-loaded, so it doesn't matter which. Twist the watch body back around, and you'll now be able to flip it over to expose the back.
Now, take a thin, strong blade (I used a butterknife) and pry off the back plate. There's a tab on the upper right edge of the back plate to make this much easier. Since it probably came off in the process, place the rubber sealant ring back around the edge of the backplate.
Once you have the back plate off, there's a thin metal piece covering the battery that's held on with one screw. Remove that with an eyeglass screwdriver or any other similarly-sized Phillips-head screwdriver. There's just a small tab holding the metal piece in place on the other side, so just flip the metal piece up a bit and pull it out. You can now take the battery (a CR2016 3-volt watch battery) right out.
But wait, what's this? Beneath that battery, separated by a small plastic insert, is another, smaller one, a 377/376 1.55-volt watch battery. The 377/376 powers the analog movement, while the CR2016 powers all the digital stuff and the backlight.
Replace both batteries, making sure to place the plastic insert back on top of the 377/376 before putting the CR2016 back in, and follow the steps in reverse to put the watch back together. You may have some difficulty getting the back plate back on, but I just pressed one side in and held it while I tapped the other side down with my fist.
Posted on Mar 27, 2016
  • Anonymous Aug 17, 2019
    Thanks! I decided to refurbish an old watch that I was given as a gift long ago, and this answer directly and accurately helps me with my (apparently) uncommon but stylish watch.
How to change the battery on a casio AW-49H watch
Timepieces Watches Manuals CASIO Go here to download the manual for your watch. Follow the instructions and you'll get the correct manual.
Feb 14, 2018 | Casio Watches
How to open a m.z berger aw222 watch to change battery
Take it to a local jeweler and they have a special tool.
Sep 01, 2017 | Watches
How to set time on m.z. berger wrist watch
Hi Hollywoo,
As far as I can see Berger watches all have what I would call a winder knob. You normally pull this out gently and then turn it to move the hands of the watch - ie: to set the time. When finished just push it back in.
Aug 08, 2015 | Watches
Need to add links to a new Elgin watch band. The number on back of watch is SR626sw
That's the battery number for the watch also known as the #377. It's the most common watch battery in the world. Your model number is located at the bottom of the dial (face) below the six-o'clock position. You will need a 10 power jeweler's loupe or magnifying glass to see it and read it. Jot down the number and contact Elgin directly (MZ Berger Co,) for the extra links.
MZ Berger.
Jun 20, 2011 | Watches
My watch didn"t come w/
Hi
This might help you having a manual.
There are two options to get a manual:
1. thru mail, you need to provide the style number found in the back or beneath the number 6 on the watch.
2,. Thru phone, you need to provide the style number then the warranty and instruction will be mailed to you.  Also can give to you over the phone.
Customer care number:  718 472 7500
Customer care Fax Number: 718 472 7661
Address:
MZ Berger and Company
Attn:  Service Department
29 - 76 Northern Boulevard
Long Island City, NY 11101-2214
Also for more information you can click this link.
I hope this will help you.
Thank you for choosing Fixya.
Mar 09, 2011 | Watches
I would like to have my son's watch repaired. I think it's a Timex but not sure. I see the word "Expedition" on the front case and a large E on the back. Some smaller letters that look like...
Just about any watch shop should be able to fix your watch, no need to go anywhere special, but if you need a place to mail too.  Here are a couple of choices for you.
Citizen Watch Repair
Dallas Service Center
800 E. Campbell Road
Suite 371
Richardson, TX 75081
(972) 234-4900(tel)
(972) 234-4901(fax)
Time-Tec Watch Svc
635 S. Hill Street
Suite 209
Los Angeles, CA 90014
(213) 488-9222 (tel)
(213) 488-9221(fax)
(888) 448-TIME (toll free)
www.Time-Tec.com
Eastside Watch Repair
E.S.W
P.O Box 8004
Mill Creek,WA 98082
(425) 641-7978
Nov 18, 2010 | Timex Watches
Battery removal?????
How do I set the watch hands, I can set the digital part, but I can not seem to change the "Hand" Settings.
Jan 26, 2008 | Casio AW80-7AV Wrist Watch
Bulova Watch Logo
1,437 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
