What do you mean by "update?" If it's corrupted physically as in bad sectors, then you replace, or turn in for warranty repair.
If files are corrupted, then run fdisk /f from the command line to check for file corruption. If the systems files are corrupt, simply run sfc /scannow from the command line.
But you really should supply more information if you want a decent reply.
SOURCE: hp v165w 16 gb pen
There could be a problem with the hardware itself,You should take it back to where you bought it..
Thank you,Please Rate me max :)
SOURCE: Where can i download driver for hp v165w USB flash
The USB driver installed by default. U need not have to install it separately. If it is not recognised then try to use it on another system, see whether it gets connected or not
