Question about Jabra BT150 Wireless Headset
I have not used my jabra bt150 for years and now it wont charge, what do i do?
5 Related Answers
informatica
Greg Cann
  • 1114 Answers
SOURCE: Manual for Jabra BT150 ????
You can download the manual & get other information from the link below: http://web.jabra.com/JabraCMS/EM/EN/MainMenu/Support/WirelessHeadsets/JabraBT150/ Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 12, 2007
sandrew
andrew pester
  • 2961 Answers
SOURCE: it wont charge
these headsets are cheaper nowadays, its not worth a repair, depending on your country you can get jabra or motorola types for around £35 GBP or $70US
Posted on Sep 02, 2007
Anonymous
SOURCE: Jabra BT150
DO AS THAY SAID HERE.......Press power button and the - and + volume buttons at the same time AND THEN WHEN THE BLUE LIGHT STOPS ON !!!!! GO TO YR PHONE AND SEARCH FOR THE HEADSET WHEN U HAVE FOUND IT ON YR MOBILE TIPE .........0000...... then you will be sorted
hope this helps c ya
Posted on Apr 19, 2008
Anonymous
SOURCE: Cannot Get Jabra BT150 into Pairing Mode
I had problem with my bluetooth not getting into pairing mode,and Now it working good.
Thank you for your best solution.
Posted on Nov 17, 2008
Anonymous
SOURCE: how to connect .
That's how you do it for other jabra's but not this one. You have turn it on then after it's on you have to hold the function (same as power button) and the volume up button at the same time until the light turns solid.
Posted on Jul 17, 2009
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
Dec 26, 2010 | Jabra BT150 Wireless Headset
How do i charge my jabra bt150
Use the AC adapter to charge from a power socket.
The charging socket is located at the top of the headset (the wider end). When the LED is solid blue, your headset is charging. When the solid blue LED turns off, it is fully charged.
Sep 27, 2010 | Jabra BT150 Wireless Headset
Cannot detect my jabra bt150 w/ my blutooth!
its a kind of virus prob plz scan ur cell
May 08, 2010 | Jabra BT150 Wireless Headset
I have the Jabra BT150 password!!
If you write down the serial number and go the the jabra site. They should be able to provide the code free of charge.
Thanks.
Jun 04, 2009 | Jabra BT150 Wireless Headset
Jabra BT150
The first dude is an idiot! The battery is toast go buy a headset that isn't as old as this Jabra! I also have the issue & no didn't plug it in wrong...it only goes one way! Mine sat for a few years unused & now will not charge...You can get newer headsets pretty cheap! Look around!
Apr 29, 2009 | Jabra BT150 Wireless Headset
Chocolate phone will not discover the Jabra BT150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Oct 07, 2007 | Jabra BT150 Wireless Headset
Steady Red Light
From the sounds of this.. It's all due to bad keying of the polarized charging plug. The solid red light PROBABLY means you're battery is pretty darn dead. It'll need a new battery(not worth the cost imho. get a new jabra, and be happy once again) At a certain low voltage, the red light starts blinking. when it drops below the preset threshold, it will shut off completely. If it sits too long at this discharged rate, the battry WILL self-terminate. If the voltage drops below a certain level, it's ruined. Also note, most Li-ion cells will only last a few years. 2-3 years of "full power" is usual. Mine's 2 years old(steady usage), and showing signs of it's age.
"My red light won't go off even though I charged it all night.
Also, a small piece of plastic came off the charge opening. I don't know if this is will pose a problem to the use of the Jabra BT150."
This is probably the most telling bit of information. It means you DID plug the charger in upside down. It will NEVER charge in that configuration, as it is supplying power to the completely wrong pins. If the battery was good to start with, it shouldn't hurt the headset, but never know. I have accidentily plugged it in backwards for a couple min before noticing, with no ill efect, but YMMV.
"Doesn't anyone from the Jabra manufacturer check this site?"
NO (especially not for discontinued products)
Oct 05, 2007 | Jabra BT150 Wireless Headset
It wont charge
Sep 02, 2007 | Jabra BT150 Wireless Headset
Jabra BT150 No power
Make sure the charger is in right. If you put it on wrong you will get a faint blue light, when it is in right you will get a BRIGHT BLUE LIGHT. It WILL NOT charge if it is in wrong.
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT150/Documents/User%20manual/BT150_UM_NA_EN_496.pdf
Link for manual
Mar 22, 2007 | Jabra BT150 Wireless Headset
Jabra BT150 Wireless Headset Logo
119 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Ekse
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
