Question about Logitech QuickCam Communicate STX Personal Web Camera
I cannot use the above cam in conjuntion with Skype
When I do it sounds as if a record is running at very slow speed
Run cam and Skype separately and all is O>K>
Posted by Peter Patiniott on
Weldon Dube'
    President:
  • 8,637 Answers
See section A. Skype in the info below.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 23, 2009
Driver download
Hello Sure ,
Check The Link Below :
To Check Your system <Xp , Vista , Seven >
And Download Full Driver .
Aug 03, 2010 | Logitech QuickCam Communicate STX Personal...
Hi, i would like to take live picturs and/or video while i am chating with skype and dont know how to do it. will you help me ? thanks, eddie
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Skype issues with your QuickCam Communicate STX trnsp.gif Detailed Description 1754.1.0.jpg This article explains what to do if you have problems using Skype with your QuickCam Communicate STX.
Model Number: V-UBK45
trnsp.gif Answer If you are experiencing difficulties using the QuickCam Communicate STX with Skype, check the following:
Verify the QuickCam Communicate STX is functional:
  1. Launch QuickCam software (Start > Programs > Logitech > Logitech QuickCam)
  2. Verify that you can see yourself in the QuickCam window as shown below:
  3. Close the QuickCam window.
Verify that the QuickCam Communicate STX is selected in the Skype Settings:
  1. Launch Skype (Start > Programs > Skype > Skype)
  2. Click Options from the Tools menu as shown below:
  3. Select the Video Settings option from the Skype sidebar as shown below:
  4. Check the Enable Skype Video checkbox as shown below:
  5. Check the "Start my video automatically when I am in a call" checkbox as shown below:
  6. Verify that your QuickCam Communicate STX is selected from the Camera drop-down menu as shown below:
  7. Verify that your QuickCam Communicate STX is selected from the Microphone drop-down menu as shown below:
  8. Verify that the "Let Skype adjust my audio settings" option is checked in Audio Settings as shown below:
If you still cannot see or hear the other person, it can be due to a variety of possible issues, including:
  • Windows or third-party firewalls
  • Your internet service provider (AT&T, Comcast, etc) could be blocking certain services.
  • Missing Windows system components.
Jan 10, 2009 | Logitech Quickcam Chat Webcam
Slow slow slows down my computer!!
Normal 0 There are a number of things that can cause the computer or the camera to freeze up or slow down.
First I’d check to see how much memory is installed in the computer. It takes additional memory to operate the camera.
May 19, 2008 | Logitech QuickCam Communicate STX Personal...
Vista
go here
http://www.logitech.com/index.cfm/435/225&cl=us,en
Sergio
Apr 13, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech quick cam communicate stx on Vista - microphone not working
Why isn't the microphone on my camera working?
trnsp.gif Answer The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
This article covers how to configure a Logitech camera's audio and video settings to work with Skype 3.6 or above. trnsp.gif Answer This article applies to the following cameras:
QuickCam Orbit AF
QuickCam Pro for Notebooks
QuickCam Pro 9000
This article applies to the following platforms:
Windows Vista
Windows XP
This article applies to the following 3rd party application:
Skype™ 3.6 or above
To set up Skype for video please be sure that your Logitech webcam is connected and working. This can be verifed by launching your QuickCam software and checking for a video stream withinin the QuickCapture video window. Once the webcam functionality is verified, please close the QuickCam application and follow the steps below.
  1. Launch Skype™ and click on "Tools" as shown in the figure below
    Fig 1
  2. When you click on "Tools" you will see a drop down list
    Fig 2
  3. Click on "Options" at the bottom of the drop-down list
    Fig 3
  4. A new screen appears. Click on the left side of the pane under "Video Settings"
    Fig 4
  5. Under the "Select webcam" drop down, please choose your Logitech camera, then click the "Save" button.
    Fig 5
  6. Click on "Tools" as shown in Fig 6 to get your Logitech Audio setup.
    Fig 6
  7. When you click on "Tools" you will see a drop down list
    Fig 7
  8. At the very bottom of the drop down list, please click on "Options"
    Fig 8
  9. When you click on "Options" you will see a new screen
    Fig 9
  10. On this new screen click on the left side of the pane under "Audio Settings"
    Fig 10
  11. You will now have the option to select your Logitech camera's Microphone as your main Audio source. Under the "Microphone" drop down, select the Logitech Microphone, and click "Save"
    Fig 11
  12. You should now be ready to use your Logitech webcam and microphone in a Skype video call.
Mar 25, 2008 | Logitech QuickCam Communicate STX Personal...
Web Cam Logitech 9000
slow computer with not enough memory and slow processor.
Feb 26, 2008 | Logitech QuickCam Communicate STX Personal...
Intermittent sound
I have notice that on some connections the speed is not fast enough to handle cam and voice at same time, If its not connections speed. He can go into control panel and run sound check for mic. It may help solve any problem if it's in the Audio drivers, And if that still does not help try a different mic. and see if that works. Hope that helps you out some what. Thanks
Jan 05, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech QuickCam Communicate STX User Manual
there should be a full manual on the CD in pdf format which accompanied the Webcam.. the 4 page guide was most likely the Quick start guide
Oct 08, 2007 | Logitech QuickCam Communicate STX Personal...
Sound delay!
It's more than likely a slow connection dependant on each persons speed, and the more people on line the more bandwidth gets taken up, it's like at peak times trying to stuff a sausage down a straw so to speak. Also make sure that there are no other programmes running in the background taking up processor and memory usage, this also slows the connection.
May 01, 2007 | Logitech QuickCam Communicate STX Personal...
Logitech QuickCam Communicate STX Personal Web Camera Logo
53 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
