Yamaha EQ-70 Home Equalizer Logo
A
Anonymous Posted on Apr 29, 2014
How do i hook up an audio control c22 graphic equalizer to yamaha rxa1030
2 Related Answers
Anonymous
  • 17 Answers
  • Posted on Aug 20, 2009
SOURCE: How to hook up my Yamaha EQ-70 Equalizer
This is official image from Yamaha. If need to know more, go to the below address -
http://www2.yamaha.co.jp/manual/pdf/av/english/am/AV-90PY.pdf
download the amp's manual & you will find on page no. 7
Anonymous
  • 128 Answers
  • Posted on Dec 29, 2009
SOURCE: I have a Yamaha HTR-5890 receiver and I am trying
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
How to hook up Yamaha RX-V1800 to Yamaha EQ70?
To hook up a Yamaha RX-V1800 receiver to a Yamaha EQ70 equalizer, you can follow these steps:
  1. Turn off the power to both the receiver and the equalizer.
  2. Connect one end of a stereo RCA cable to the "TAPE OUT" jacks on the back of the Yamaha RX-V1800 receiver.
  3. Connect the other end of the RCA cable to the "INPUT" jacks on the back of the Yamaha EQ70 equalizer.
  4. Connect another stereo RCA cable to the "OUTPUT" jacks on the back of the Yamaha EQ70 equalizer.
  5. Connect the other end of the second RCA cable to the "TAPE IN" jacks on the back of the Yamaha RX-V1800 receiver.
  6. Turn on the power to both the receiver and the equalizer.
  7. Use the EQ70 equalizer to adjust the sound as desired.
Note: Be sure to select the "TAPE" input on the Yamaha RX-V1800 receiver to hear the audio processed through the equalizer.
Can i hook up my bose 901 equaliser to a Yamaha A S701 amplifier?
Yes, you can hook up your Bose 901 equalizer to a Yamaha A S701 amplifier. Make sure to use the appropriate cables and connectors to ensure that the signal is transmitted properly. Additionally, make sure to check the amplifier and equalizer settings to ensure that the sound is balanced.
Can you hook up a pyramid graphic equalizer 8600 to a Pioneer receiver audio video multi-channel vsx - D 912
The ideal way to do it is to hook up the preamp outputs of receiver directly to equalizer and the equalizer outputs to the amp inputs on receiver. Then unit will work with all sources.
How do I hook up an equalizer to my Yamaha RX-V630 Receiver ?
you hook it up through your tape monator just like you were hooking a tape deck up if you have a tape deck pluged in there you should be able to plug it in to the back of equalizer the same way
1helpful
Can i use a graphic equalizer with a yamaha as-500
My Yamaha Equalizer is Model GE-30. Review the manual for this unit and on page 3 you will see the connection procedure "Line Out" on the equalizer to "tape deck in" on the amplifier. In the case of the A-S500 user manuaI on page 5, I used the "line 3 " also identified as "tape deck" to connect the equalizer.
The front control(s) from page 2 on the A-S500 manual are then set :
Control(5) input selector set to Line 3 (Graphic Equalizer)
Control(8) REC OUT selector to CD (for CD), line1 (my blu-ray player, or tuner (my DVR/tv)
The only thing I lose is "PURE DIRECT" does not fuction if the equalizer is on, otherwise;
I simply set Control(5) input selector swith to the desired input source, the equalizer no longer
functions and "PURE DIRECT" can now be used.
The rest of the tonal controls for bass, treble, balance, and loudness work as they should.
1helpful
I have a Yamaha HTR-5890 receiver and I am trying to hook up a Yamaha EQ-32 10 band graphic equalizer to the receiver. The frequency spectrum analyzer on the equalizer is working but the graphic...
2helpful
2answers
Connect Equalizer to Yamaha receiver
You do this the output cord or RCA cord of your yamaha reciever is to input in your graphic equalizer ,the output of your equalizer is in to the speaker that all .. feel free for asking assistance for further question arises rate as fixya...
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
