Question about VinoTemp (VT60GNV) Wine Cooler
Vinotemp wine cooler just stop working.
I had this cooler for approximately 1 year. Never held temp that was set. It just stop working. No power. Why does this happen?
Posted by Danielle richmond on
Michael
    New Friend:
    Problem Solver:
  • 13 Answers
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
Posted on Apr 29, 2014
3 Related Answers
Anonymous
SOURCE: wine-cicles
I found the vinotemp trouble shooting webpage that has good info for several different VT models. Here is the link. http://www.vinotemp.com/troubleshoot_pdf.htm
I emailed VT and they gave me a price for the parts
VT-TC32ECB -$34.95 (control board)
VT-60Sensor -$14.95
here is their services information
Jane Barron
Service Department
VINOTEMP INTERNATIONAL
[email protected]
T 310.886.3332 x231
800.777.8466
F 310.886.3310
Posted on May 30, 2008
Anonymous
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
Jacques Alexandre
  • 183 Answers
SOURCE: i have a vinotemp VT-12TEDi
The thermostat may be bad. Test it with multimeter set in "ohm" to confirm that is defective before replacing.
Posted on Dec 12, 2010
Vinotemp 28teds doesn't work, no fan, temp or light, what's up
Probably somewhere in its history there was an incident of total failure.
Dec 31, 2013 | VinoTemp 28Bottle FreeStanding Wine Cellar...
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
Vinotemp 2 zone wine cooler flashes "Lo" on numeric display for lower compartment - will not hold temperature requested. Temp in upper compartment will not go below 67 even though it is set for 51. Room...
Not sure, but did you clean the filter in the back? Ours has that, and the temp starts creeping up every few weeks until I clean it. But we've never been able to get it below 58 or so, and in the last year, not below 60. I think that's just the nature of this type of cooling. Our house is also at 80. But, can keep it at 60 with the above cleaning.
Jul 22, 2009 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp VT28TEDS - circuit board
VinoTemp hotline: 1-800-777-7778
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2009 | VinoTemp 28Bottle FreeStanding Wine Cellar...
Vinotemp 24 - keep hearing ticking sound
It's the overload protector thats gone bad. Remove the plastic cover on the side of the compressor( LG model NS30LACG). The OLP is the one on top. If you open it up you will find that it may have some burn marks from electrical arcing. The part number is on the side (P6R8MC). Do a Google search for it. It costs about 12 bucks.
Jan 12, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Wine-cicles
VT-60Sensor -$14.95
Jane Barron
Service Department
[email protected]
T 310.886.3332 x231
800.777.8466
F 310.886.3310
Mar 18, 2008 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp (VT60GNV) Wine Cooler Logo
533 people viewed this question
Top VinoTemp Furniture Experts
jasbo
jasbo
John Tripp
John Tripp
ray gallant
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
