How do I turn the light off?
SOURCE: what is wrong with passenger window 2004 volvo xc70
sometimes the window clips, or guides, can loosen. if you're not careful and keep operating the window, it could contact the window regulator arms and bend them. this will require window regulator replacement
SOURCE: I have to replace the ballast for the HID
You need to remove the front bumper. Five push clips along the hood line, remove the headlight wipers (if equipped), one T25 screw in the front of each fender well, then two 12mm bolts under the headlights (1 each side). Then there are 4 10mm bolts holding the headlight in.
SOURCE: in a 2001 Volvo XC70 the wrong fuse was removed
remove the batter cable for a while and replace it back ( negtive cable)
SOURCE: headlight bulb replacement
There should be a cap or cover behind the lamp assembly under the hood. 1/4 turn counter clockwise (if it is a hard cap) should expose the bulb and retaining spring (clip). Squeeze the clip to release it from lamp assembly. unplug old bulb, plug in new and then do the opposite to replace it. Good luck, them clips is the devil.
