Question about Philips (33-01-031) Headphones
Will headphones work with jensen cd-560? - Philips (33-01-031) Headphones
Posted by cwheelere on
How to clean the tuner on Jensen JCR-560?
They make a special spray for that purpose.
How can I get sound from my radio
If a cable speaker is shorted to ground or (in your case) the short was on the casing the radio mutes the output to save the amp. So
remove all cables and put them back to the radio & connect the speakers one by one to see if it works or mutes again
1helpful
2answers
Can't get headphones to work on this unit
Aux-in jack is used to play another device such as an Ipod or other sources through your Jensen player, using it as some sort of an amplifier. Look for another port on your Jensen player that says "audio out" or "Spkr" (means speakers) to plug in her headphones. If you can't find any of these ports then you might have purchased a n actual boom box, which does not have the capability to play through headphones, sorry about that.
Want to add boom box speakers to my pc
You could use a fm sender to go from the computer headphones and tune in the boombox radio to play the sound..
2helpful
Just need to know how to set the time and Alarm
the 3rd button on the first row said stop/TIME
it only works as "STOP" when the "FUNCTION" knob is on CD otherwhise is the "TIME" setting button akong with the "MINUTE" & "HOUR" buttons in the same row
Jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
Rear zone sound not working
Do you have the manual? Here is the link
http://mobile.jensen.com/jensen/docs/man/VM9512_DOC_OM.PDF
And is no IR transmitters in the unit. Let nme know if you still have audio issues aftr reading the manual.
Peace,
Larry T
Winona Lake, IN
16helpful
2answers
NEED HELP SETTING THE TIME
i had the same issue; with a little bit of experimenting I was able to set the time. Hold down the stop/time button until it displays 12A (it might display 24H first - do it again if you don't want military time to get the 12A) Let go then press stop/time again so the time blinks. Use the hour and minute buttons to set the time appropriately. When satisfied, press the stop/time button again.
Philips (33-01-031) Headphones Logo
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
