Question about Motorola Mobility StarTac Boom Headset
Motorola boom driver
Not installing
Posted by junior on
DR NITIN KHANDELWAL
  • 383 Answers
First check if it's a Compatible one. Read user's manual for compatibility of your Boom Headset. If it's compatible, you should once again try to install it, but first uninstall partially installed or erratic installations previously made, then re install it. Before doing so, take Backup of your Phone.
Posted on Apr 28, 2014
My Motorola h15 bluetooth won't turn on. Please help!
Kristina-
Put your H15 on the charger overnight with the boom closed. In the morning open the boom and see if it lights up as expected.
Mark
Motorola SUpport
Aug 02, 2014 | Motorola Mobility MOTOPURE™ H15 Bluetooth...
I just purchased a Motorola h15 and the charged it last night. I flipped down the boom to turn it on and it doesn't turn on.
Kristina
Did you charge with boom closed? How did you you know it doesn't turn on? Are there any lights?
Mark
Motorola Support
Motorola 550 boom broken boom
Contact Motorola Support: http:/www.motorola.com/support
Jun 26, 2014 | Motorola Mobility H550 - Bluetooth Headset...
Where is driver for motorola boom
Contact your PC manufacturer. They probably have drivers for your hardware and OS.
Mark
Motorola Support
May 12, 2014 | Motorola Mobility HS850 Consumer Headset
My Motorola H730 won't stay charged
Jess
Are you charging with boom closed and closing boom when not in use?
Mark
Motorola Support
May 29, 2012 | Motorola Mobility H730 Bluetooth Headset
How to pair motorola H700 wireless Headset with my treo 650
Open the headset boom: it will flash steadily purple, it it's not paired ever. If it was paired turn that devices off; open the headset boom, blue will steadily lit; after 5 seconds, it will steadily purple lit. Now find Motorola H700 on bluetooth and type password: 0000. Done!
Dec 18, 2010 | Motorola Mobility H700 Wireless Headset
How to connect motorola bluetooth hs850 to motorola V3 chandrabose
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 10, 2009 | Motorola Mobility S9 Headphones
I have a blackberry curve and am wanting to pair my bluetooth HS850 to it. Please help!
There actually is a trick to the HS850 - flip the boom closed, then hold down the button just until the light holds solid - IMMEDIATELY after it does flip the boom open and this should keep the light solid. Then on your cell/device search for bluetooth devices - you should be able to find it now. Passkey for most devices is 0000.
Jun 30, 2008 | AT&T Blackberry Curve 8300 Smartphone
Motorola H700
To put the H700 in pairing mode, have the boom closed and hold down the call button. The light should turn purple, then open the boom. Connect to your phone.
Nov 15, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility StarTac Boom Headset Logo
161 people viewed this question
Top Motorola Mobility Radio Communications Experts
JonSnell Electronic
JonSnell Electronic
George Scott
George Scott
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
