Question about Freezers
Bosch Fridge Freezer (KAN62V40GB)suddenly started beeping and the temperature has increased. The normal alarm whent he door is not shut correctly is a continuous tone, however this is beeping like an
KAN62V40GB/04 FD9010 I have run the self test and no E has occured on the display?
Posted by Charlie Gartland on
  • Charlie Gartland
    Charlie Gartland May 01, 2014
    We have had to have an engineer and it is the circuit board which is a 'rare' fault, of course it is, rare cost involved too, just happens to be outside of the warranty by 6 months as well, how convenient.
mike cooper
  • 884 Answers
Check the condenser is clean and the fan running normally, Any excessive heat from under or behind is a sure sign the fan may need replacement.
Posted on Apr 28, 2014
5 Related Answers
Anonymous
  • 93 Answers
SOURCE: fridge freezer door alarm continuously beeping
make sure gasket is sealing also make sure light is going out.
Posted on Jul 18, 2008
Anonymous
SOURCE: Freezer temperature increases then goes back down on Frost Free Bosch Fridge Freezer
have you cleaned the condencer? dan
Posted on Jul 19, 2008
Raz Mataz
  • 389 Answers
SOURCE: Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my bosch fridge freezer's alarm light has started
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 02, 2010
miket756
Michael Thorpe
  • 2702 Answers
SOURCE: Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Posted on Jun 29, 2010
Freezer alarm
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Sep 06, 2013 | Electrolux Freezers
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
My Miele freezer the alarm bell is bleeping but it is not defrosting what could be the problem please.
The beeping could be a low temperature warning. Check to make sure the temperature is staying cold enough and then check the door seal. Use a store bot fridge/freezer thermometer. Use a dollar bill to check seal. If you close door on the bill it should hold the bill tight but still let you pull it out. If it is loose then you need to adjust the door to fit tighter.
Sep 21, 2010 | Miele Freezers
Bosch fridge frezer
gas is sealed for life....sounds like it is auto defrost mode.leave switched on. after a full manual defrost. for at least 24 hours to settle down keep door shut... then check. should reset itself.make sure all vents,drains are clean.
Feb 14, 2010 | Freezers
Jan 26, 2010 | Freezers
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
After power cut the temperature of the fridge and the freezer termperature are just flashing and making a beeping noise
It means the compartment temperatures are increased then allowed limit.Generally in some appliances the maximum temperature is indicated at the display with an alarm after the electric cutoff.If the temp is high in the compartments
Jun 29, 2009 | Whirlpool Freezers
Fridge freezer door alarm continuously beeping
Jul 17, 2008 | Freezers
Freezers Logo
587 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
