SOURCE: PS3 laser Problem
It sounds like you bought a defective laser or it is the chip on your "sister board". There is a chip on the circuit board thats on the bottom of the Blu-Ray drive and it has a silver rectangle on it. Some say that that chip is going bad on some machines. I have repaird 60+ PS3's this year and I haven't had this happen to me yet though. I would suggest trying another laser, then if that doesn't work try a "sister board" from the same model of PS3. I'm still not possitive if that is a possible solution though. The "sister board" is supposedly keyed to only work with the mother board it came with. Well, I hope this helps. Good luck!!
SOURCE: PS3 won't recognize disks after update
You can back up ANYTHING you wish to keep via the backup utility what I'm about to tell you to do will essentially erase your harddrive. After backing up any data you wish to keep, restore your PS3 system and to a FULL ( not quick ) format of your harddrive ( this will probably take a couple of hours ). After that, if it still doesn't work call SONY.
Hope that helps..........
SOURCE: Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
SOURCE: my ps3 wont load any games
Check all of your settings and make sure everything is configured properly. If you made any changes to you system configuration just before this issue happened just change back to previous config and see what happens.
If everything is correct, then, unfortunately cleaning the lens is not going to help very much. This is similar to the "disc read error" on the boxy ps2. The best thing for you to do is to call sony and tell them that your blu-ray player is not working you can only read regular dvds. It has happened to a few people that I know and they were still under warranty and it was replaced. If this happens to be a common issue then maybe Sony will still replace it outside of warranty. Never know, but it is always worth a shot.
This is the 2nd most common problem
with PS3's. This isn't a bad problem. Your laser/lens will need to be
replaced. There are many videos on youtube if you would like to do it
yourself (I would advise you not to). I recommend that you find a
technician who has experience. There are many things that can go
wrong.
