Maytag SAV5710 Top Load Washer Logo
A
Anonymous Posted on Apr 27, 2014
How to replace belt on Model maw 5000 - Maytag SAV5710 Top Load Washer
A/c belt screaming.
change fan belt and check tensioner are ok too
2helpful
2answers
Need the wiring diagram for MAW-603-rh-wh
http://www.lutron.com/TechnicalDocumentLibrary/0301122A.pdf
On the first page, its the wiring diagram smack-dab in the middle.
If you couldn't find it before, its because the MAW-603-RH-WH is a package containing two other products, the MA-600 and the MA-R. So the instructions I have noted above are appropriate.
I have a Meastro dimmer MAW-600 W that is installed, but the light does not turn on and the LED keeps blinking. Any idea what the problem can be?
1) If this installation was working before, the Maestro has a small pull-out circuit breaker that lets you reset the device. This is called the FASS Front Accessible Service Switch, located at bottom of dimmer where it meets cover plate.
Open sample Lutron Maestro dimmer manual to see FASS illustration
http://www.lutron.com/TechnicalDocumentLibrary/0301106A.pdf
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which excludes CFLs apparently.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on outlet on same breaker to see if line has interference.
3) I don't see MAW-600 W listed among Maestro dimmers, so I don't have that specific manual.
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
4) Amazon certainly shows the MAW-600 W, in case you need a replacement.
http://www.amazon.com/Lutron-MAW600H-WH-Electronics-Maestro-Dimmer/dp/B000BPCWQE
5) Lutron has customer service numbers:
1.888.LUTRON1 (588.7661)
1-800-523-9466
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Fixya is always less expensive than a service call.
I bought a MAW-603 with an accessory dimmer to be placed in a 4 way circuit. I followed the instruction on how to connect the accessory dimmer in the 4 way switch location but doesn't work. When I leave...
You are saying that you have a "4-way circuit". That means that you originally had two 3-way switches and at least one 4-way switch. ALL existing mechanical switches _must_ to be replaced with electronic dimmers in order for things to work correctly. You must have only _one_ master dimmer (MA-600) located wherever you desire. All of the other switch locations must be companion dimmers (MA-R)., NOT mechanical switches.
The MAW-603-RH comes with a master dimmer and one companion dimmer, so I suspect that you need to install one more companion dimmer.
2answers
I have a Lutron Maestro MAW-600 switch connected to 2 pendant lights and the 2 pendant lights bulbs blew. I replaced the bulbs but the lights still do not come on. The Lutron switch flashes green rapidly...
Lutron Maestro MAW-600 manual:
Single-Pole 600 Watt Halogen/ Incandescent Dimmer (minimum 40 Watt)
Lutron technical support 1.800.523.9466
You said pendant lights blew out.
How many total watts were those lights?
Did you remove aluminum break-away fins on side of device to match wattage?
Front indicator can be pulled out to cut power to circuit.
This is called FASS switch.
Try pulling out FASS switch and then pushing it back to see if it re-sets device.
Click breaker on-off to see if it resets device.
You replaced a single-pole switch that has two wires plug ground wire.
Each wire from switch goes to either screw on MAW-600 so it's hard to go wrong there.
Bare copper goes to green ground screw.
Otherwise, it looks like tech support is next step: 1800-523-9466
3helpful
3answers
Mitsubishi Washing Machine (English Manual) MAW-YP7 Manual Request
The spin cycle stops in less than a minute,it doesnt complete the spin cycle
I have a GT 5000 CRAFTSMAN RIDING LAWN MOWER THE DRIVE BELT CAME OFF I NEED TO REINSTALL CAN YOU PLEASE HELP?
Something caused the belt to come off. Find the reason,fix it and put the belt back on if it was not damaged.
Hi is the cassette player in the 5000 stacking system belt driven regards cliff
beocord 5000?. if so yes.there is a capstan belt clutch belt and a counter/autostop belt.there is also a deck in/out belt.
Replace HP designjet carriage 5000 belt
you need some skill and expertise, if you have, download the service manual
http://www.eserviceinfo.com/equipment_mfg/HP_22.html
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
