Question about Dell Dimension E520 PC Desktop
Whining fan dell E520 computer
Loud fan
John Ryder
    Scholar:
    New Friend:
  • 94 Answers
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Posted on Apr 28, 2014
Dell Dimension E520 Hard drive constantly buzzing
This could be a sign of a failing hard drive - I would backup all of your important documents immediately to an external drive to prevent you from losing any important data.
As you have already cleaned out the dust , there is a chance that one of the system fans (or the CPU fan) may be faulty or some wires inside your system case might be catching on the fan while it is spinning.
Disconnect all the system fans , so just the CPU fan is left plugged in and then switch on the system and see if the noise has stopped. Then plug each fan back in one at a time to identify if any of them are causing the noise.
Dec 01, 2013 | Dell Dimension E520 PC Desktop
My E520 Dell shuts down in to the energy save mode after 1 minute of booting and then the high speed fan comes on and screen goes black
off the energy save mode...it goes revert of ur action...re-install opreating system..is it work? clearfy
Mar 16, 2012 | Dell Dimension E520 PC Desktop
The CD/DVD drive will not play or burn Cds or DVDs. Just started to 'go wrong' yesterday. Its a Dell E520 running Vista Home Basic
The easitest way restore your computer several days back, or your system recovery which comes with the computer when you first purchased it.
Oct 13, 2010 | Dell Dimension E520 PC Desktop
Hi, I'm getting excessive fan activity from my Dell E520, can you advise before it takes off. thanks
it means the pc is verry hot try cleaning the fan or run iobit advance system care to optimise the pc
Sep 26, 2010 | Dell Dimension E520 PC Desktop
Where can i find Dell dimension E520 drivers, such as ethernet controller
Access the manufacturer's web-site: http://support.dell.com
Enter the unique "Dell Asset ID" code (black type on a white decal on the back-panel of your desktop computer), to get information about *YOUR* specific computer, including device-drivers.
Sep 15, 2010 | Dell Dimension E520 PC Desktop
I turned off the Dell Dimension e520 before a storm. I have tried numerous times to turn it back on, only to have a yellow flashing light. How can I get my computer to turn on?
Good day.
Here's my point of view of you problem. I have also experienced the same problem since it is always raining here in the Philippines. I just have to ask a few questions before i can give a direct solution to you.
Please provide the following:
1. Do you have a voltage regulator in your computer set. 2. Do you hear a beeping sound everytime you turn your computer on after the incident happened? 3. Does the processor fan still runs after turning your PC on or not? 4. Kindly provide your computer specs.
Good day and should you have any questions regarding the questions, feel free to approach us.
Jun 15, 2010 | Dell Dimension E520 PC Desktop
I added a 4 port usb card to a dell e520. The
try updating the drivers to the card to see what happens. another solution is try it on another computer. if the same problem exists on another computer you could have a bad card.
Mar 30, 2010 | Dell Dimension E520 PC Desktop
Dell e520 e deive not accessible
Try the drive in another computer. If this is happening at the bootup process, the drive may have failed or the cable may be bad. Also check the BIOS settibg s to make sure the drive is setup properly.
Jan 28, 2010 | Dell Dimension E520 PC Desktop
Where do I find the usb port on my dimension E520 Dell computer?
E520 has 2 usb ports on the front right where the card readers are. It also has 5 (Five) on the back right where your ethernet cable hooks in.
Oct 02, 2009 | Dell Dimension E520 PC Desktop
Dell E520 case
The Dell E520 Service Manual details how to remove and i stall all the components/parts of the said computer. It may be found here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 10, 2008 | Dell DimensionTM E520 PC Desktop
Dell Dimension E520 PC Desktop Logo
70 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
