Sounds like you have a glitch. Try to remember when it started and then go into your start menu, type in 'system restore' and follow the instructions and select a time before the problem started. That should help with this and a lot of other issues.
Check to make sure that the "remote turn on" lead is intact. They are usually blue wires.This wire provided a turn on voltage to fire up the amp once the head unit is turned on.
how do I transfer my pic off my digital camera sd card into my p9740 I put the card inside it read it but I can't program the pic to choose one as my screen saver...do u have a solution?
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Sounds like there could be a shorted wire possibly power but what sounds like happened is the unit grounded out and blew the cigarette lighter fuse. Check fuse box for blown fuse, if this is the case I would suggest pulling radio out and having the wire harness for the radio professionally connected and inspect all connections
