Question about Casio FX-300MS Calculator
What is the line segment same size in length of circumference of a circle
1 Related Answer
  • 102366 Answers
SOURCE: Exponential Functions
A classic. This is one of Zeno's Paradoxes.
Posted on Jun 07, 2012
If the circumference of a circle is 15m what is the diameter?
You can go to https://www.omnicalculator.com/math/circumference and calculate.
Anyway:
The diameter is the length of the line through the center that touches two points on the edge of the circle.
Aug 27, 2017 | The Computers & Internet
I need the diameter of a 2 circle.
Circumference Calculator
If the circumference is 2, then the diameter is 0.63662 of whatever unit of measure of length is applied.
Aug 22, 2017 | The Computers & Internet
The radius of a circle is 3 centimeters. What is the length of a 90° arc?
circumference is pye times twice the radius or by the diameter
3.1417 X 6 ( diameter or 2 times the radius )= 18.8496
90 degrees is 1/4 of the circumference
18.8496 divided by 4 = 4.7124 cms
arc of 90 degrees =4.74124 cms
May 02, 2017 | The Computers & Internet
15" circle what is outside measurement
If you would like to know the circumference of a 15" diameter circle this is the formula:
circumference = radius x 2 x pi
circumference = diameter x pi
in our case:
circumference = 15" x 3,14
circumference = 47 ,1" (that's 119,634 cm)
May 06, 2014 | Cars & Trucks
Trying to determine if a tangent is present when a triangle overlaps a circle
In which language? This is really more a mathematical problem than a programming/compilation one. Try walking the circumference of the circle, testing for a point along each of the triangle's segments. If only one such point can be found, or a series of consecutive points (since software "circles" are never true circles, they're made up of short straight segments), then you have a tangent.
You can save a lot of time and math by making coarse estimates first - for example, don't bother testing for tangentiality for any circumferential segment that's fully above, to the left or right of, or below, all three points of the triangle - you CANNOT have a tangent in those areas.
An alternate approach is... walk the triangle instead of walking the circle. Test for a single circle crossing point. Again, you can save time by checking each segment first, and walking only segments that actually cross the circle's circumference. If no part of the circle can be found mathematically between any pair of vertices, then discard that segment outright.
Mar 10, 2014 | Computers & Internet
I have a problem concerning radians and angles
About 146 and a half degrees.
If this is homework, be sure to show your work.
Oct 22, 2013 | Office Equipment & Supplies
How to find the length ot the arc ,a circle has a radius of 45cm.
You can not do it unless you know the measure of the central angle sustending (supporting) the arc. If the angle is known, you use the proportionality relation that follows:
If angle is in degrees
(length of arc) / circumference=(measure of central angle sustending arc)/360.
Here the circumference is 2*PI*radius.
If angle is in radians , the relation is somewhat simpler,
arc length= (radius length)* (angle measure in radians)
It is clear that in the last relation, the unit for the arc length is the same as the unit for the radius.
Jul 15, 2011 | Casio FX-300MS Calculator
Find the radius of a circle in which a 40o central angle cuts off an arc whose length is 4pi
If an arc is 4╥, it is 12.56.
You can use 12.56 as a starting point and figure out what circumference that is 40° of.
Circumference = 2 • π • radius = π • diameter
Reverse this and you will have your answer.
Oct 12, 2009 | Computers & Internet
A 30o angle cuts off an arc in a circle with a diameter of 10 in. Find the length of the arc to the nearest hundredth.
The arc length can be obtained by:
(pi x r x Angle) / 180
or
(3.1415 x 5 x 30) / 180 = 2.618 in.
Hope this helps...
Sep 15, 2009 | Vivendi Math Blaster Geometry for PC, Mac
Casio FX-300MS Calculator Logo
50 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
