Question about Transcend T.sonic 610 MP3 Player
Head set wornout
One side of the head set first wornout. And some days later the other side also wornout.Whether I can get a replacement. Because it was purchased 4 months ago.
Posted by Maran on
ThaMp3Doctor
  • 8,597 Answers
My 99 passatt 1.8 turbo couple of week ago I replace passager side head light then two weeks later I replace the same bulb it work for about 3 weeks then one day no drl and no regular head lights just...
Its a German car and they are known for electrical problems. Your problem lies within the Drivers light assembly, check the voltage voming into the headlight socket with multimeter and see if there are any voltage spikes or drops, alternating.
Oct 16, 2013 | Cars & Trucks
I bought a 2000 lincoln ls about a month ago and after we bought it, it started having an over heating problem. Since then, we put new fan, new t-stat, new coils and valves, new radiator cap, new belts,...
I believe you have a head gasket or cylinder head problem (cracked head or blown head gasket).. If it is the gasket, the intake and cylinder head must be removed and a new gasket installed.. If it is the head itself, in addition to what have just said, you will have to have the head repaired or get a reconditoned or new one. This is a major repair.
Mar 25, 2011 | Lincoln LS Cars & Trucks
Head lamp keeps burning out. replaced head lamp at
You either have a bad ground or the bad electrical connection at the light socket is "simulating" a bad ground. This is putting a high resistance on the bulb and it's taking it's toll by burning out the bulb. I would start with a new socket, and CHECK the ground. If you still have the issue, I would run another complete ground wire and not even worry about checking the ground itself. the Stick
Dec 10, 2009 | 2006 Suzuki Grand Vitara
Need to know roughly how long it would take to replace the head gasket in a 1996 buick century, 3100 V6...?
Depends on your level of experience, quality of your tools and whether or not you have any frozen head bolts. The valve assembly and head come off as one unit on those. To clear the wires, emmision controls ect off of the top of the valve cover 30 minutes. remove valve cover 5 minutes (too scrape off excess gasket material. to remove exhaust manifold from side of head, (assuming no broken/stuck/stripped bolts 15 minutes with good hydraulic tools. To remove head (assuming all goes well and hydraulic tools, 15 minutes. To reassemble, double all times as surfaces need to be prepped and gaskets applied and proper torque on all bolts. It's an afternoon job if you ahve everything you need and nothing goes wrong. Typically add at least two or three hours of drilling and cursing to a head gasket replacement. and a trip for new drill bits and a tap (not beer) for the new hole you drilled.
May 13, 2009 | 1996 Buick Century
White smoke
Sounds like you've got a leaking head gasket. Check your coolant and see if there's any black gunk in it, if there is you for sure have a leaking head gasket.
Oct 01, 2008 | 1996 Chrysler Town & Country
Cartidge prob??
you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Remove the ink carts.
on either side of the carrage there is a screw, remove both of them.
CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
also carefully remove the silver "fingers".
remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
lift the head (you see 4 nipples in there-- that is the top of the head assembly)
gently pull out the ribbon cables.
on the bottom of the head is 2 screws, remove them
now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
get some windex with amonia.
soak the parts for a day or 2.
blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
this works 90% of the time
any further assistance reply me
i am always here to assist you
thank you
bye
Apr 15, 2008 | Lexmark X1240 All-In-One InkJet Printer
Still says "replace ink cartridge" even after I did replace it
Apr 13, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart c6180
Feb 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
Images are unclear
if you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Feb 09, 2008 | Office Equipment & Supplies
Transcend T.sonic 610 MP3 Player Logo
Top Transcend Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
