Question about Taylor 7532 Ultra Thin Glass Digital Scale
I weigh 68 .3 kilograms how much do iweigh in stones and pounds
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
10 stone 10.58 pounds
Posted on Sep 26, 2014
1 Related Answer
Anonymous
SOURCE: How do I change the scale to read pounds instead
Turn over the scale, on the bottom, there should be a little black switch that you can use to select between lbs and kilograms.
Posted on Jan 03, 2010
Salter scales weighing more than double the weight
Sounds silly but check the scales for a Kilogram or Pounds switch. its usually under the scales and is a sliding switch. It should tell you on the display if you are weighing in pounds or kilos.
Sep 15, 2014 | Health & Beauty
What is 19. 77200 in stones and pounds
If you mean kilograms, 19.772 kg is about 3 stone 1.59 pounds.
May 20, 2014 | Office Equipment & Supplies
What does a kilogram weigh in pounds
One kilogram is about 2.205 pounds.
May 06, 2014 | Office Equipment & Supplies
8 stones 7 75 pounds in kg
If you mean 8 stone 7.75 pounds, it's about 54.32 kilograms.
Jan 22, 2014 | Office Equipment & Supplies
Stones to kilos conversion
About 3.62 stone or 3 stone 9 pound.
Nov 08, 2013 | Office Equipment & Supplies
I need to know how to convert cumic meter into kilograms
You can't. Cubic meter is a measure of volume, while kilogram is a measure of mass (or weight). It would be like trying to convert gallons to pounds.
Now, if you wanted to know how many kilograms a cubic meter of water (or gold, or...) weighs...
Jan 20, 2011 | Office Equipment & Supplies
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Taylor 7532 Ultra Thin Glass Digital Scale Logo
78 people viewed this question
Top Taylor Health & Beauty Experts
Marvin
Marvin
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
