Question about Pioneer PD-M406 6-Disc CD Changer
Pioneer pd-m406 cd changer magazine style
I own a Pioneer PD-M406 6 disc cd player that skips alot, especially on cd-r type cds. I have used a cd/dvd cleaner which is a disc with tiny brushes on it but it doesn't solve the problem. The player is about 10 years old. Can I solve this problem on my own?
thanks
Posted by pjkeys on
  • pjkeys Feb 21, 2008
    The solution offered by guest is incorrect. The cd player plays all types of cds, including cds I have made myself.
  • takmor Oct 05, 2008
    Yes, exactly the same problem also just after about 10 years. CD's that did work correctly until about hafl a year ago do now skips alot, especially CD-R's, so it seems the read-mechanism is making more errors (or the error correction electronics is doing worse). Opened the unit but found nothing looking suspicious so not found a solution.
Anonymous
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Posted on Feb 20, 2008
I have my late husband's Pioneer PDF906, (100 disc capacity) and I created eleven music CDs on my computer which play perfectly in my computer, my car and my DVD player, but with the PDF906, only the...
The last 3 discs might be CD-RW which can be rewritten, but not all cd players will be able to read them. Just go to the store and buy some CD-R disks and re-burn the last 3 disks. That should solve your problem.
Jul 28, 2011 | Pioneer PD-F906 100-Disc CD Changer
My pioneer cd player PD- m501 skips tracks and cds sometimes!!! why?
it could be lots of things, how many hours of use your player has? (laser opticals have a life time) are you using cheap recorded CD's? ar the speakers too close to the player (loud base could make it skip) the laser optical could be dirty try a cleaning disk.
Jan 04, 2011 | Pioneer Audio Players & Recorders
My Pioneer PD-M403 will not play computer made CDs. Why won't they play?
incompatibility is the cause of the problem. There is nothing wrong with both your player and the computer made CD's, they are not just clicking with each other.
The Pioneer PD-M403 player is also an old model, this could cause the problem.
There is not settings whatsoever that you can use ti solve this problem.
Take care.
Sep 25, 2010 | Pioneer PD-M403 6-Disc CD Changer
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
The cd player skips
hi, you may need to run a disc cleaner for the optic drive must be dirty, check the cds too for minor scratches that makes the disc skips too. hope this helps
Feb 13, 2010 | Pioneer DEH-16 CD Player
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
Will not recognize CDs
ur eye inside the cd player is probley cut somehow or just really dusty or dirty,. I hope that works
Nov 18, 2008 | Pioneer PD-M406 6-Disc CD Changer
Cd changer home stereo pioneer system
pioneer cd players have the common problem of losing their laser lens due to the glue that holds it in place going brittle over time. try shaking the player from side to side and upside down to see if you can hear the lens rattling about. if you recover the lens, very carefully slot it back in place and apply a tiny drop of glue (NOT SUPERGLUE) to the outside edge of the lens taking care not to get any on the focus area and leave to dry. all should be well after this. i find UHU GLUE in the yellow tubes do a lasting fix but don't use SUPERGLUE as the fumes will coat the lens.
hope this helps?
Jan 05, 2008 | Pioneer PD-M406 6-Disc CD Changer
Pioneer PD-M406 6-Disc CD Changer Logo
632 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
