SOURCE: vista drivers for hp officejet 5610
Download and install Adobe Reader, if you do not have it
use Get Adobe Reader Button at this link
http://www.adobe.com
Use this link to determine your product number
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpu04090&product=12019&lc=en&dest_page=product&cc=us
You may want to bookmark the link you pick from here for reference
software and drivers download link in the left gray column
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=officejet+5610&submit.x=9&submit.y=6
The second option for each of the machines on the Software and Drivers Download page is to order a CD. It will ask for your zip code and indicate a price to get it to you based on the speed you request for delivery.
Another option would be to have a friend or family member with a faster internet connection download it and either burn it to CD or copy it to a usb flash drive (it is < 200 MB) a 250MB flash drive should work and bring it to your machine to load.
SOURCE: HP Officejet 5610 All-in-one printing in red instead of black!
Hi ,
As you have already tried replacing the ink cartridge , u can try to reset the printer .
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
Note - you can also try the Ok n cancel key combination in place of # and 6 .in case the first combination does not work .
Thanks
SOURCE: HP Officejet 5610 stopped printing
turn the printer on and unplug the power cable from the back of the printer without turning the power off
press and hold :
OK and CANCEL, while keeping them on hold put the
power cable back in ... it ll do a full NVRAM reset on it .. then it ll
prompt u for the language and country follow the steps it ll be
resolved ...
Best of luck
SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
Windows users: Turn on printer.....
In the HP Solution Center, click Settings, point to
Print Settings, and then click Printer Toolbox. Click the Estimated
Ink Levels tab.
Mac users:
In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
Hope this works for you....Eye
