Question about KitchenAid Dishwashers
Why does my Kitchenaid dishwasher model 8524569 run so long?
It runs for 1 hour and 40 minutes even on the Energy Saver setting?? Why is it so long and how can I shorten the time? Thanks
Posted by Rick Giguere on
Sam
  • KitchenAid Master
  • 3,247 Answers
It is likely the heater is not working effeciently and takes a long time to heat the water to the set temperature. Try and run the rinse cycle and see if that takes much shorter as this does not need to heat the water. Please provide the full model number- xxx. xxxx or KUD..etc.
Posted on Apr 28, 2014
5 Related Answers
Anonymous
SOURCE: Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
Posted on May 30, 2008
Anonymous
  • 70 Answers
SOURCE: Dishwasher continues to run beyond necessary time
most likely the microprocessor has failed
Good Luck!
Posted on Feb 21, 2009
erpaalai
Eric Duda
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
techbuster
INDIRA KUMAR
  • 5081 Answers
SOURCE: KitchenAid dishwasher KUDS25SH - Can't operate because child lock
If holding the "Energy Saver/Dry" button does not solve the control board problem then most probably the control board would have failed and needs to be replaced .
To identify it we need technical expertise in handling the circuit boards and knowledge on usage of multimeter is must.
Posted on Nov 08, 2010
mddog26
  • 77 Answers
SOURCE: Kitchenaid dishwasher 8524569 won't start
If the dishwasher won't start you likely have a bad fuse. Click on the link to download a video to see how to replace the fuse on your washer.
Appliance Repair
And to order the fuse just go to the Fuse Link
Posted on Mar 16, 2011
How do you turn off power saver on frigidaire air conditioner
Good Afternoon Friend,
I understand you want to know how to turn off the power save mode for your Frigidaire air conditioner, model# FFRE12L3Q1. Your appliance will run in energy saver(econ) mode when used for the first time. In this mode, the fan will continue to run for 1 minute after the compressor shuts off. The fan then cycles on for 20 seconds at 10 minute intervals until the room temperature is above the set temperature, at which time the compressor turns back on. You will be able to turn the energy save mode off by selecting your temperature as well as your fan speed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Heating & Cooling
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
Samsung Refrigerator Error Code 1E or IE
I'm not sure what all the wild goose chase answers are all about, but you guys are WAY overthinking this and not solving the problem. I'm a 45 year old stay at home mom, decidely and possibly forever "un-handy". The solution is simple, as I just administered it this morning after a self-imposed power outage: Press the "Energy Saver" + "Lighting" button simultaneously for 3-5 seconds and you should be back in business. When this happened on a previous occasion, we had a repair guy come out, although the fridge was operating perfectly bc we weren't sure if that error message was indicating something important. Well, I felt like a schmuck when the guy showed me how to reset the panel (and we were both a bit irritated that phone tech support didn't do a better job of level 1 troubleshooting). So there it is...if your fridge is working fine but showing 1E, press Energy saver + Ligthing at the same time (you may need a flashlight since the panel will be dark).
Aug 20, 2012 | Samsung RF4287HARS French Door...
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
What does energy saver do ?
Hello there
Energy saver alows you to minimize the amount of energy used to run the appliance efficently thru different settings on the appliance
To use the Energy Saver option:
  • Press the control to On to save energy when the environment is less humid.
  • Press the control to Off when the environment is warm and more humid, or if moisture is noticed on the hinged seal.
  • I hope that this has been very helpful for you
  • Best regards michael
Nov 06, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Computer turns off unless constantly using... even put to sleep, it turns off instead.
Hi, Sorry you are having problems,
Sounds to me like either your energy saving preference pane is set WAY too short or it is corrupt.
Go to your system preferences and select (Energy Saver) and be sure it is set to never sleep and set the idle time to screen sleep time to about 30 minutes and be sure the button ( Shutdown instead of sleep ) is not selected... if you have that button.
Try these, then do a restart to be sure they take.
If you still have the same problem, then, your settings are corrupt, you will need to delete it:
go into your hard drive, into your user folder, into the library folder into the preferences folder and find this file:
com.apple.systempreferences.plist
put it in the trash, empty trash, restart the computer the reset your energy saver settings and you should be OK!
Mar 10, 2009 | Apple iMac G5 Desktop
Propane consumption
1/3rd of a gallon per hour on high. It will not run on high all the time. .3X24=7.2 gallons worst case.
Sep 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Wake up from energy saver mode
the menu where you set the time once you've scrolled though all the time options will give the option of disabling it.
Jul 10, 2008 | IBM 6400 Matrix Printer
New Dell desktop computer - installed Norton Security 2007 - sreensaver and energy modes don't work
Since Norton and many other virus protection programs run in the background of the computer, when you try to go into standby mode, or screen saver mode, the program is recognized as an action by the user, hence triggering the computer to return to normal use. So all you have to do is turn off Norton before you go into standby mode, and this should fix the problem.
Feb 10, 2008 | Computers & Internet
Reset timer for energy saver mode
Every new unit comes with the user's manuals, and every new unit has free tech support from the vendor. What you are looking for is under the "System Settings" found after pressing "Additional Functions".
Oct 18, 2007 | Canon ImageRunner 3320N Copier
Dishwashers Logo
344 people viewed this question
Top KitchenAid Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
