Cameras Logo
Question about Sony Cameras
My SD card won't go into my Sony camera, Can I fix it myself?
SD card wont go in anymore in to the camera what do i do?
Starry
I have the same issue. I tried unlocking it. It doesn't go in, and I'm using the same SD card I had inserted before. There's nothing broken inside the slot. I need help...
Posted on Jan 01, 2023
5 Related Answers
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: my sd card wont fit anymore
be more clear ....how come it doesn't fit ...maybe it is fitting but not work ??I don't thing it is possible to not fit in the same spot ...if it doesn't work ..see that it has a locking device on it ...its just a little slide button on the side...
also look carefully maybe its damaged physically...or maybe the slot has something inside...like a strange object or so .... .....or you just used another card...or if now seams smaller...it used to have an adapter for it ...
Posted on Jul 24, 2009
Crankstart
Chris
  • 696 Answers
SOURCE: SD card locked for Samsung SL202
This used to happen occassionaly with my canon camers. Just use a peice of scotch tape or if you have one a small dab of hot glue to stop it from sliding.
Hope this helps FixYa,
Chris
Posted on Sep 03, 2009
Testimonial: "Scotch tape worked just lovely!!! Thank you!"
Anonymous
  • 797 Answers
SOURCE: my easyshare camera won`t format my SD card, but
To format the card in the computer card reader would be a way to see if the card can be formatted.
Make sure the little switch is up or in the position to format or write to the card.
If the card can be formatted in a card reader, then the card is okay. But the card should always be formatted in the camera you will use it in. There can be corruption of files when systems are mixed on one card.
Make sure that all the menu settings are at factory default, then set them as you please.
Posted on Sep 27, 2009
Anonymous
  • 6831 Answers
SOURCE: Camera won't accept an SD Memory Card anymore
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
damneddle
damneddle
  • 1607 Answers
SOURCE: No memory card registering in SONY Nex 3 however SD card is loaded??
Try another SD card. Also, make sure you formatted it using the camera.
Posted on Aug 20, 2012
Sony sd card wont work on my kodak af 3x
My guess: your sony card is a SDHC card. Or when it can store more than 32 Gbyte, it is a SDXC card. Both won't work in your Kodak camera, because it only can handle MMC and SD cards.
You still can buy SD cards, but most of the time they can't handle more than 2 Gbyte. Take care, because most memory cards with 2 Gb capacity are already SDHC.
I put sd card and the camera wont turn on
Dear Noel,
The possible causes behind this problem would be:
1) SD card might be damaged or damaged directory structure.
2) The Camera won't support the existing SD card and sadly, you'll need to purchase a new one.
Please check with these and most probably, you can easily address the issue.
Thanks,
I reformat my sd card in the computer to remove all the photos the when im using it in my sony cybershot camera it appears "reinsert memory card" how can i fix the it to use it again in the camera
When you need to delete the photos from the SD memory card, do not use your computer to do it. Use your camera to format the SD memory card.
To fix this problem, insert the SD memory card in your camera then go to the camera's Menu and format the SD memory card.
Why wont my toshiba sd card read on my camera nikon cool pix ?
Make sure your memory card is an SD card and not an SDHC card. If it's larger than 2GB then it won't work with the 3200.
I bought a 4gb memory (Sony) card. I t shows unsupported when turned on , is it compatable?
The M415 works with SD cards. Your 4GB card is actually an SDHC card and won't work with the camera. You need to use SD cards, 2GB and smaller.
How to fix reinsert memory card from sony DS - W330 digital camera?
Hello.
Remove the SD card then replace it back. If you are still having a problem, format the SD card using the camera. If that still doesn't solve the problem, you need to replace the SD card with a new one.
My SD card won't stay in camera
Fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Hi, my camera doesnt save pics on the SD card anymore. how can i fix it?
have you proove to change the sd card???
why if the camera make this problem with other cards...i am sorry but this is a great problem.. that is a problem from the internal card reader.
I don't know if something fell in my sd slot, but my sd card wont go all the way down anymore. What can I do to fix it?
Are you sure the card is being inserted properly? If it's wrong, it won't go in all the way.
25helpful
2answers
My memory card on my camera say it is protected
you look on the memory card, there will be a lock slider thing,it might be on lock , check it,
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
