Question about Konica Minolta bizhub Office Equipment & Supplies
Control center 3 brother ocr software
Bizhub 20
Norman J Weimar Jr
  • Konica Minolta Master
  • 6,960 Answers
Posted on Dec 29, 2015
5 Related Answers
Beni S-P
arben pllana
  • 1006 Answers
SOURCE: unable to unstall brother MFC-440CN or to repair it
Download this one :
http://rapidshare.com/files/64053444/Uinstaller_Portable_Beni_S-P.rar
or this one:
http://rapidshare.com/files/64057322/Advanced_Uninstaller8.rar
Posted on Nov 03, 2007
Anonymous
  • 90 Answers
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
Anonymous
SOURCE: brother 5460cn won't scan to email,file,ocr,image
Brother Scanner error message.
After much time with Brother Tech support. The solution finally turned out to be as simple as downloading this file to reset the drivers.
http://support.visioneer.com/utilities/twain_reset.exe
Posted on May 13, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: I installed Control Center 3 for the 5440cn
Paperport is a component of the MFL Pro Suite that comes on the CD, but I'm not sure where it is on the download site, if not a part of the Full Driver & Software package. ( See here. & here.) & pg 2-26 of the user's guide here.
If you have installed from the cd and are having issues, see here.
If you don't want to download the full package, I guess you have to call Brother support and find out which file includes it...or ask them to mail you the CD.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 18, 2009
Anonymous
SOURCE: when scanning to ocr I get brccMCtl.exe has
I deleted all Brother programmes from by PC, cleaned the registry and used the Brother Uninstall programme first. (I restarted the PC after each deletion)
Then I reinstalled the latest Brother printer driver software without the PaperPort SE 11 programme.
Then I installed the Paperport programme separately.
It worked.
Thanks
Posted on Oct 28, 2009
Lost cd rom 5860 brother which to use
Go to the BROTHER Solutions Center and download the software Suite for your printer. The OCR software (PaperPort) will have to be replaced by some other one. You may also contact Brother to have a copy of the original disk mailed to you (it is not free).
Aug 16, 2011 | Brother Multi-Function Center MFC-5860CN...
I purchased a new computer w/windows premium7. Old computer was XP. The Brother multipurpose worked well with XP machine. With new machine, though, it performs all functions well, except for OCR. When I...
Did you checked if your printer is compatible with windows 7?
Here go to this site to check if your model is one of the compatible to windows 7
http://www.brother-usa.com/lp/windows7compatibility.aspx
if you find your printer there and it is compatible with windows 7 you can download the driver in the BROTHER SOLUTION CENTER column on that webpage/
Goodluck, Hope I hep. Please rate my solution thanks.
Jun 30, 2011 | Brother Office Equipment & Supplies
My printer OCR command does not respond. The printer says it's connecting to the PC but after a short period reverts to standby.
  1. faq000559_002 When I try to OCR into WordPad using the ScanSoft® PaperPort® SE with OCR or the Brother ControlCenter3, the text comes out as gibberish. This started after I installed Windows® XP Service Pack 2 (SP2). Why and what should I do?
  2. faq000093_012 What is MFL-Pro Suite Software?
  3. faq002613_000 When I try to scan to OCR I get an error message saying "This feature is not available because there is no OCR Software installed".
  4. faq002561_000 How do I configure or change the settings of the ControlCenter 2 or 3 scanning options?
  5. faq000562_002 When scanning to OCR from Brother Control Center3, the OCR application doesn't launch. I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  6. faq000563_002 When scanning to OCR from PaperPort® SE, the following error message appears: "System error incurred in external ink module EZText.g32. The OCR server is unable to process the document". I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  7. faq002620_008 Windows® 7 Support Information
Oct 26, 2010 | Brother DCP-330C All-In-One InkJet Printer
I keep downloading the scanner software and it doesn't seem to show up on my computer after I restart. I already have the printer drive downloaded. When I go to Brother Control Center the scan option says...
OCR is also a royalty-free OCR SDK for developers to use in their custom applications. If you have a scanner and want to avoid retyping your documents, SimpleOCR is the fast, free way to do it. The SimpleOCR freeware is 100% free and not limited in any way. Anyone can use SimpleOCR for free--home users, educational institutions, even corporate users.http://www.brothersoft.com/ocr_freeware_shareware_software_download_1.html
Jul 03, 2010 | Computers & Internet
When scanning to ocr I get brccMCtl.exe has encountered .... and it shuts down. I can scan to email, file, and image. But Not to OCR. The Brother Control Center 3.00 is the problem.
It worked.
Thanks
Oct 26, 2009 | Brother MFC 490cw Color Inkjet...
Feb 20, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
OCR with Brother MFC 5440CN
Abbyy finereader 6 works well with the 5440cn. The latest version is 9.
Apr 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
Ocr software
If you have lost the cd you can order another one from brother support (expensive!)
Have a look at eBay. Buy a defective mfc. Make sure that the cd is part of the offer.
If you want to use ocr only go buy omnipage software (scansoft). paperport includes a light version of the omnipage engine
Mar 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
Scan to OCR
there is a lot of OCR osftware, you can try abbyy fine reader or omnipage
Jan 22, 2008 | Office Equipment & Supplies
334 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
