Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator Logo
Ed Kuespert Posted on Apr 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice switch dispenses water - Samsung RFG297AARS (285 cu ft) Bottom Freezer French Door Refrigerator
  • Ed Kuespert
    Ed Kuespert Apr 30, 2014
    ice is being made. when i push the ice dispenser switch all that comes out is water. this is a door with a switch for ice and a seperate switch for water. there is no electric sound when i depress the ice switch.
  • Ed Kuespert
    Ed Kuespert May 02, 2014
    its is a samung 4 door refrig
maniman
Level 2:
Scholar:
New Friend:
  • Expert 73 Answers
  • Posted on May 17, 2014
maniman
Expert
Level 2:
Scholar:
New Friend:
Answers
73
Questions
0
Helped
49595
Points
102
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Ice dispenser on refrigerator has quit dispensing. ice maker and water dispenser still work. fuse, switch? What do I need to do?
https://www.youtube.com/watch?v=p9GjSqi6eY4
https://www.google.com/search?source=hp&ei=yj52Xrn4O9aGjLsPjY2MkAY&q=Ice+dispenser+on+refrigerator+has+quit+dispensing.+ice+maker+and+water+dispenser+still+work.+fuse%2C+switch%3F+What+do+I+need+to+do%3F&oq=Ice+dispenser+on+refrigerator+has+quit+dispensing.+ice+maker+and+water+dispenser+still+work.+fuse%2C+switch%3F+What+do+I+need+to+do%3F&gs_l=psy-ab.3..0i362i308i154i357l6.3892.3892..4963...0.0..0.280.280.2-1......0....2j1..gws-wiz.....6.KpTP5CQ-W1Y&ved=0ahUKEwi5hZO9_KvoAhVWA2MBHY0GA2IQ4dUDCAU&uact=5#kpvalbx=_8UF2Xqv7BqLHxgOu8YKYDw57
2answers
Ice maker isn't working. Water is not filling the tray but the water dispenser in the door works fine.
could be frozen water fill tube to Icemaker. or solenoid water valve is not opening when ice maker calls for ice. there are 2 separate solenoid valves : one for dispenser another one for ice maker.
GE Profile refrigerator model PFSS6KW/PFSF6PKW not making ice.
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
Ge psc23ng no ice
  1. Dispenser switch
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Search Over 2 1 Million Appliance Parts
GE profile refrigerator ice maker not working
  1. Dispenser switch
  1. Door switch
  1. Dispenser switch
  1. Door switch
Water dispenser doesn't work
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Why is my GE Profile Refrigerator ice maker no longer dispensing ice?
  1. Dispenser switch
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Ice machine not working
  1. Dispenser switch
  1. Door switch
Ice maker not functioning or producing ice cubes
  1. Check connections
Check all hose connections to ensure that water is being transmitted through your appliance and there is no frost build up.
  1. Feeler arm
Double check to make sure your feeler arm is not stuck or that ice cubes are not blocking the feeler arm's motion to produce more ice.
  1. Ice maker heater
The heater may be stuck on. The heater comes on for 1-2 minutes to break cubes free from mold. If the heater stays on too long ,the ice maker will get hot and stop making ice. Carefully feel around the ice maker mold; if it is hot to the touch, the heater is on. This indicates that the ice maker is jammed, and it is better to replace ice maker than to try and repair it.
The water valve supplying the ice maker is a key component of the ice-making system. When the ice maker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. When this part is not operating correctly, a repair/replacement part may be needed. Refrigerator Repair Help Troubleshooting and Parts
3helpful
Ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
1helpful
2answers
Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
