Question about Magic Chef Furniture
Why is my Avantgarde Wine Cooler very loud when running. Is this normal?
When it clicks on the motor runs loudly. Not sure if this is normal or a problem.
Posted by Barbara Seguin on
5 Related Answers
Anonymous
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
Posted on Jul 08, 2008
Anonymous
SOURCE: wine cooler noise
I wrote up a blog entry for a minor modification we made to our Danby wine refrigerator to silence noise from the upper fan:
http://www.adrianmccarthy.com/blog/?p=79
You can find quieter versions of the fan with the same specs at big computer parts stores (for the PC builders who want quiet computers). The one we got cost less than $20. We also added rubber spacers so that the fan vibration isn't amplified by back panel of the fridge (which otherwise acts like a soundboard). Made a huge difference.
Even with the fix, though, I wouldn't ever recommend the Danby models. Their noisy, and we've had multiple breakdowns in five years. The only authorized repair shop in our area has lousy customer service and high prices.
Posted on Sep 29, 2008
Anonymous
  • 3 Answers
SOURCE: Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Posted on Apr 13, 2009
Ken Bledsoe
  • 306 Answers
SOURCE: Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on May 03, 2009
Rich Wright
  • 286 Answers
SOURCE: U-Line 15WC wine cooler not working
First make sure your condenser is clean and the fan is going. If everything is running and still doesnt cool enough then you need a repair person to check the sealed system.
Posted on May 18, 2009
Just plugged in my new 12 bottle Danby wine cooler and it hums, LOUDLY. Any idea why?
it might , it has a compressor and that would make more noise under a strain . refrigeration units strain when the box is warm. let it run and bring down the temp of the box and then see how much noise it is making . 12 hours should do it.
Jan 30, 2016 | Danby DWC1233BL-SC 12 Bottle Wine Cooler
Wine cooler cools but has a very loud, too loud to ignore, whirring sound when it is in cooling mode. Any ideas?
And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
Jan 19, 2016 | Refrigerators
ITS NOT COOLER ITS IS ABOUT 3YRS OLD
IF it is running now:
Check the "coils" along the bottom or back, and dust them off with canned air.
Check the seal along the door, it may have been sprung by opening all the way too many times. To check the seal, take a note card (or business card) and place it in spots between the seal and frame for the cooler.
IF it is not running or running very loud:
Unplug the unit and let it warm up to room temp (transfer the wine into several good cooler boxes first...) and then leave it for several hours, then start it up again, this should help.
Topbarhive
Jan 12, 2016 | Danby DWC350BLP Wine Cooler
My magic chef wine fridge keeps making a loud popping noise every 15-20 minutes. It s model # WCMC458?
I have a Magic Chef wine cooler making that loud popping noise - Model # MCWC45MCG Could you let me know the way to fix it if possible or where to take it considering I live near Indianapolis, Indiana?
Aug 15, 2010 | Magic Chef MCWC45A Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
Thernoelectric Wine Cooler not cold
check internal and external fans are running if not replace them
Jul 27, 2009 | Refrigerators
We got a Haier 42 wine cooler. The motor doesn't run.
This is something you can not fix yourself. Remember it might cost as much as a new wine cooler to repair. As for free estimate on repait. That way if it cost to much your not out anything. Rus
Jun 17, 2009 | Haier BC112G Wine Cooler
Haier wine cooler produces intermittent loud "motor" noises.
Turn the unit around so you can hear the compressor (large black small basketball size unit lower left) if the sound is coming from that then it is probably lost lubrication or just failing. "These usually last forever but.... they do fail. I am not sure if this one (loke mine) has a samll fan. Clarify the noise for use and we can tell you what it is. a constant tapp tap tap fast paced is the compressor going out or out of lub etc. . A ting ting ting may be a fan... Robert-Aptos
Apr 28, 2009 | Haier BC112G Wine Cooler
Furniture Logo
259 people viewed this question
Top Magic Chef Furniture Experts
Sheldon Dedek
Muntejaya Ginting
Muntejaya Ginting
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
