Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
HOW DO I TURN OFF THE CONTROL LOCK ON MY KITCHENAID DISHWASHER
The Control Lock light is on. I think there is an easy way to reset but cannot remember how.
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Posted on Mar 25, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Have a kitchenaid dishwasher KUDS25SHWH1 - the
Unplug the unit for 15 minutes then plug it back in. This should reset all your computer system and make everything work again
Posted on May 28, 2009
erpaalai
Eric Duda
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
Anonymous
  • 6 Answers
SOURCE: Dishwasher KUDC25CH; Control Panel is not working
WASH THE DISHES URESELF U LAZY ****!!! :)
Posted on Oct 17, 2009
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
Mar 07, 2018 | Whirlpool Washing Machines
I don't remember the pattern screen lock for my
Im thinking you have to reset it, you might lose contacts but my sister reset her phone and it was better than having to pay to get access to her phone.
Sep 13, 2013 | Android Root/hack/mod Your Phone/tablet...
Can you turn off the FPA lock without an original remote? If so, how?
If you remember your pass word then you can use any remote that operates the TV to reset the menu selection. However if you don't remember the password, then sorry, the original remote must be used.
Below is the procedure to set up the menu for front panel lock, unlock and the password reset.
Front Panel
Selecting this option lets you lock (disable) or unlock (enable) the TV's front
panel buttons. The remote still tunes to any channel so remember to remove
access to any remote that can operate the television.
1. Choose Parental Control from the Main Menue and press the OK button.
2. Enter your passworcd.
3. Press the down arrow to highlight Front Panel.
4. Press the right or left arrow button to choose unlock (_) or lock (_).
I don't remember my password and I want to unlock the TV
If you forget your password, you must reset it. Make sure the TV is of. Press VOL- (down) on the TV's front panel and then
CLEAR on the remote for approxhnately 5 seconds. The TV turns on. Enter a new password next time you access
the PARENATAL CONTROL menu or the TIME_menu.
Feb 17, 2011 | RCA 20F512T 20" TV
CONTROL LOCK SHOWING; HOW CAN IT BE RESET?
Hello
Resetting the control lock light is very easy, you can press and hold the END OF CYCLE button for 15 seconds. This is a common issue with whirlpool duet washers and the fix is simple. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is locked. I unplugged and plugged bach
holding the end of cycle button is the control lock,not the door lock. Check to be sure that the control lock light is off--if not, hold end of cycle button again till control lock light goes off.
I've given up on the door lock after a few years fighting it, and researching. There is a solution on fix-it that may work--if it is computer(mother board I think they call it)--and not door lock mechanism. I've read many posts from duet owners that replaced door lock mechanism just to have it be a soldering problem with the "mother-board" that makes the machine "think" there is a door lock failure.
Here is link to a fix-it post I used today to get my machine open and retrive clothes it has held hostage for several days:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Control lock will not turn off
the far right set of buttons lowest one, if you looked closely is marked "control lock" hold for 3 secs, the control light will go off
Oct 26, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
How do you reset forgotten parental control password?
for the phillips and magnavox tv sets the code is 0711, then open the menu setting restet the code to something easy to remember , or what i would do is completly disable the child lock by going to that option in parental settings.try it hope it works!
Apr 14, 2008 | Philips Magnavox 27MS343S 27" TV
Control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Jan 01, 2008 | Washing Machines
Focus Problem
Low light focus lock can be a problem with this camera. But in normal or bright light there should be no problem with auto focus lock. If this is a new problem, you should check to see if a setting has been changed. With so many options, it is easy to accidently set something that causes unusual results (been there, done that). First ... Go to the Setup Menu and see that the "All Reset" option is selected. This will cause everything to be reset to factory default each time you power-on the camera. Turn the camera off and then turn the camera on. Then take some test photos to see if your auto-focus-lock is improved. If that works, there is no need to check the items below. If that does not work, here are some control changes to try. Remember if you turn off the camera everything gets reset. That camera uses contrast detection for auto focus and it is normally set to "Multi-Area Auto Focus". Try changing it to "Spot Auto Focus" and do some tests, including with the camera set to one of the programs or manual mode. There is another setting called "Autofocus Area", you should investigate. Check your manual to determine what you can do with this control. There is another control called something like "continuous auto focus". Check the manual for further information. If none of the above help, it is time to see about some camera repairs.
Sep 06, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
704 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
