Question about Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony kdl-46xbr4 power source repair - Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
5 Related Answers
Anonymous
  • 320 Answers
SOURCE: XBR4cuts off and blinks six times
A 6 flash failure indicates a backlight problem, either from the backlight inverter board or the backlights in the panel failing. There is a simple problem that sometimes causes this; loose screws holding the boards in place. You can try removing the power, taking the back off the set and tightening down the screws that secure the boards to the frame. the screws are aatually a ground connection and if they are loose it can cause problems. if this doesn't help, you will need a tech to look at it.
Posted on Nov 15, 2008
Ranjith Kolary
  • 89 Answers
SOURCE: Standby LED blinks in red continuously KDL-46XBR4
If the Standby light is blinking at the front panel of the TV, it seems that there is an internal malfunction occurred in the TV. I will forward a link to a page where you can get more information and troubleshooting steps for this issue. http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467 Please perform the steps provided on the page. If the issue still persists then service of the TV is required.
Posted on Jun 16, 2009
Anonymous
SOURCE: Sony kdl-46xbr4 Black Horizontal Bands When I First Turn on TV
I had the exact same problem with the Sony KDL46XBR4. The problem started 11 months after I purchased the TV (Dec 2007). Luckily I placed the call to Sony just before the 1 year warranty expired and they replaced the entire front panel which is basically the whole TV except for the stand and the plastic frame. Last month the same issue started happening again (5 months since the repair). I called Sony and they say they have a 90 day warranty on the replacement part so I would need to pay out of my own pocket to first have the problem diagnosed (it's the EXACT same problem!) and then pay to have the repair done since the warranty has expired. I asked how much the front panel costs and it's $1,400! I paid $2,100 for the TV when I purchased it. Interestingly, at the time that part was back-ordered.....hmmmm, I wonder why??? Perhaps a recall is warranted here (no pun intended). Needless to say, I have sworn off Sony products due to their lack of support for this issue.
Posted on Jun 28, 2009
Anonymous
  • 7 Answers
SOURCE: have multiple images on screen also verticle lines
Sony is now extending the warranty on the LCD display and will fix the problem for free through September 30, 2012. See: http://esupport.sony.com/US/perl/news-item.pl?news_id=378&mdl=KDL46XBR4 Call their customer service number and they will give you a case number. Then call one of their authorized service centers and they will fix it free, in home.
Posted on Jan 27, 2010
Anonymous
  • 7 Answers
SOURCE: sony kdl-46xbr4 turn on and shuts off try 10 times
If the problem is with the LCD display unit, Sony is now extending the warranty on the LCD display and will fix the problem for free through September 30, 2012. See: http://esupport.sony.com/US/perl/news-item.pl?news_id=378&mdl=KDL46XBR4 Call their customer service number and they will give you a case number. Then call one of their authorized service centers and they will fix it free, in home.
Sony KDL-46XBR4 46 in. LCD flashing light. Light flashes red 8 times pauses
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC. Try this link too.
Dec 20, 2013 | Sony KDL-46XBR4 46 in. LCD Television
Sony BRAVIA XBR KDL-46XBR4 HDTV LCD Television
you need to replace defective capacitors in the power supply of the tv
Jan 05, 2013 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
Sony kdl-46xbr4 will not turn on
most likely you have faulty capacitors in the power supply. Do you have any experience in electronics repair??
May 28, 2012 | Sony KDL-46XBR4 46 in. LCD Television
Sony kdl-46xbr4 turn on and shuts off try 10 times
Dec 30, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Dark area on Sony LCD screen model KDL-46XBR4
This model of SONY TV uses a Samsung display panel, the problem you have is the panel went bad.
SONY was offering an extended warranty to change the panel free, please call SONY to check it out that if they still offer the free replacement.
Sep 26, 2017 | Sony KDL-46XBR4 46 in. LCD Television
Sony kdl-46xbr4, horizontal lines
Sony is replacing LCD Panels at no charge until October 31 2012. The KDL46XBR4 and KDL46XBR5. If you paid to repair they'll pay you the cash back you paid to repair it.
Jun 11, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV Logo
62 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
