Question about Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony flat screen-kdl-46 - Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
5 Related Answers
Anonymous
  • 20 Answers
SOURCE: I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
Posted on Mar 11, 2009
RNS-Systems
RNSeStore.com
  • 120 Answers
SOURCE: Need replacement screen for Sony Flat Screen TV
Replacement screens are to come by. Check E-bay try and find a TV that wont power on. Also www.RNS-Systems.com Has used screens from time to time
Posted on Oct 16, 2009
Anonymous
SOURCE: yellowing spots on my lcd flat panel tv
Just had Best Buy's Geek Squad in to rectify this problem.They replaced the whole panel and the yellowing still appeared. Thankfully under extended warranty. Going into Best Buy today to replace the TV.
Posted on Jan 30, 2010
Anonymous
  • 49 Answers
SOURCE: sony 46 KDL 46S2000 screen went black and the
you can referen the article:
How to Fix a Black Screen at Startup
maybe it can give your some help
Posted on Mar 05, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: I need a replacement screen
You can try contacting www.shopjimmy.com
It will be more than the TV is worth, better off selling the TV for parts on EBAY, then use the money toward the new TV. LCD panels are limited production run, and it is the most expensive of the whole TV.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 19, 2010
COLORED VERTICAL LINE ON THE ENTIRE SCREEN AND NO PICTURE Sony Bravia KDL-46VL160 46 in. LCD HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 03, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How to do default settings on sony bravia kdl-46s4100
If there is an answer to this question, you will most likely be able to find it on AVSFORUM dot COM - once there go to the LCD Flat Panel Displays section and then search or scroll through the list of models. The Bravia kdl-46s4100 is approx 6 yrs old, so what you're looking for is going to be somewhat buried and by this time the discussion thread may even be closed, but whatever information is there should be extensive, as this was a popular model when new. Note also that the "46" in the model number refers only to the screen size (46") so information for any KDL-xxS4100 (where xx = the screen size) should be relevant to yours. Hope this helps.
Jan 19, 2014 | Sony KDL-46S4100 46 in. LCD TV
Sony Bravia KDL-46Z4100 46 in. LCD HDTV TV does
Probably its not a problem. On the menu You should have a Headphone audio level control (when needed you can mute the set speakers and still have headphone audio).
Oct 10, 2013 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
My lcd flat screen plastma tv screen got broken.i want to know is is repearable.
KDL-46S2000 Panel cost approx $1500 +$3000 core charge, Part # 1-802-100-31.
Parts reference: Andrews electronics, 800 289 0300.
May 08, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Jan 24, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Black streaks appear verticaly on my screen.
hi this might be happening because of your cable if that isnt the problem then you will have to contact sony and let them know what is happening with tv
Jan 10, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
