Question about Hitachi 43FDX01B TV
Hitachi screen went blank?
I was adjusting the convergence (3x3 mode) and was working on the right sections and all of a sudden what looked like a distorted sound wave swept the screen from left to right and the screen went blank.
Anyone know what's happening. I've unplugged it to see if a hard reset may help. Appreciate any suggestions.
Posted by mspomer on
  • mspomer Nov 03, 2007
    sorry, should have said a 43FDX01B. Thanks
Vista Electronics
    Genius:
  • 1,694 Answers
1) Consult service manual for details.........procedure issues?
Sounds like the digital convergence unit got confused....
You may have to start all over again at default....
2) When converging a PTV, less is better ( adjustments) unless
you are positive adjustments will yield some improvement..
3) Info source = www.HitachiServiceUSA.com
Please rate this solution.............................
Posted on Nov 15, 2007
Lcd looks a red wave line it look like it's out
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 29, 2010 | Hitachi 51GWX20B 51" Rear Projection...
There is a wave/bow in the bottom and top of the picture on the screen of my Toshiba 70HX50. When I am in the grid screen in the service mode it looks like the center is 'bowed' out. How do I adjust this...
*Screen Looks 3-D
*Colors wont align
May 15, 2010 | Toshiba 43H70 43" Rear Projection...
My tv is blurry, showing green and red waves...zenith d61w25
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
I have 46ux13k hitachi tv and i need to know if there is atrick to adjusting the convergence.
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACHI REMOTE. NONE ELSE WILL DO
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
ONE COLOR WILL NOT MOVE. YOU WILL NEED TO MOVE OTHER COLORS TO ALIGN TO IT.
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Mar 21, 2009 | Hitachi 43FDX01B TV
Convergence problem
This is out of the service manual
don't forget to write the setting to rom by hitting the pip button twice
Good luck and don't hesitate to ask questions
2.12.5 Convergence point adjustment
Adjustment preparation
(1) Select color to adjust.
“STATUS” - Green
“0” - Red
“ANT” - Blue
(2) Use 4, 6, 2, and 5 to move the cursor position
(dotted lines).
(3) Use thumb stick to move the convergence point.
(4) Three adjustment modes are available:
For touch-up, only the (13x9) mode is necessary.
This will adjust every cross-hatch intersection point
on the screen.
For complete adjustment, start with (3x3) mode. This
will adjust center point and eight edge points only,
but will greatly reduce adjustment time. Then use
(7x5) mode, and finally (13x9) mode to finish
convergence.
If “S” distortion appears between cross-hatch lines
repeat (7x5) mode to change calculation process
while adjusting to remove distortion, then return to
(13x9) mode to finish touch-up convergence.
Adjustment procedure
(1) Receive any NTSC signal.
(2) Start adjustment at the center of the screen.
(3) Continue adjustment at next closest position.
(4) Adjust center area first, ending with edge sections.
(5) Press INFO button to perform calculation operation.
This process will take about 2 seconds and no
picture will be seen at this time.
(6) After interpolation, check convergence again and
repeat (1)-(5) if necessary.
(7) When convergence is acceptable, press PIP MODE
(8) DATA WRITE TO ROM will take approximately 4
(9) Green dots will be displayed when operation is
completed.
(10) Press MUTE to return to convergence pattern, then
(11) Press PIP MODE (ROM WRITE) mode, then press
PIP CH to initialize sensor data positions.
(12) Input any 1080I signal.
(13)Press EXIT key 5 times to exit video mode.
(14) Select an input with 1080i signal.
(15)Access menu and select ASPECT 5 mode.
(16)Press the SERVICE SW. ONLY button to enter to
DCU crosshatch signal.
(17)Repeat steps 2~11 above.
Notes: (1) Display only green for easier adjustment and
match to jig screen. Press “MENU”, THEN
PRESS “STATUS”.
(2) Perform interpolation and data write to ROM
after green adjustment. Once green has been
confirmed to match jig screen, the jig screen can
be removed. Do not readjust the green color
after jig screen has been removed. This is now
your reference color.
(3) Display green and red only and match red to
green.
(4) Display all colors and match blue to green and
red. Touch-up red color if necessary.
(5) Existing DATA in ROM can be read by pressing
the SWAP button 2 times. This data can be used
after replacing a component (CRT, DY, etc.)
Where complete convergence adjustment is not
necessary, be careful not to overwrite this data.
DO NOT write cleared RAM data into ROM or a
complete convergence adjustment will be
necessary. Remember to try MAGIC FOCUS
before starting convergence adjustment to
minimize adjustment time.
Feb 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
DOUBLE IMAGE HITACHI ULTRAVISION TV
Ok, I would suggest before you buy anything from anybody is to try to do a manual convergence.
1) Receive an NTSC signal.
2) Press Magic Focus to begin magic focus
3) Press magic focus again during the magic focus process to get the ?stop? screen
4) While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and
5) When you first get in here? I believe red is the selected color by default (it is flashing).
6) To choose other colors to converge, use the following buttons on the R/C:
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
7) Start from the center of the screen and work your way out on one color at a time. I adjusted red across the
(a) Use 4, 6, 2, and 5 on the R/C to move the cursor position(dotted lines).
(b) Use thumb stick to move the convergence point color.
** There have been other posts in here to tape together the color filters found in the Avia DVD to help converge
lines more easily. I have used this method, and it works well for adjusting to a greater detail. Basically, you put the
red filter next to the green and adjust your red to the green line both horizontally, and then vertically. Then you do
the same with the blue next to the green. Some people recommended you should be at normal viewing distance. I
did mine from just a few feet back from the set. Maybe my eyes aren?t as good? maybe I just felt like it worked
better this way. There are some other posts also recommending using binoculars. I think it?s great that people
suggest things to make the process easier? but my girlfriend would think I was insane if she saw me with
binoculars on the couch adjusting the convergence. I don?t know? whatever works best I guess.
8) I did not adjust the green at all. I use the green as the guide and did not adjust the location of any green point.
This is highly suggested unless you have geometry problems.
9) When going along the lines and adjusting, you may run into the problem of getting an ?S? curve on the line.
You?ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
1. (3x3) Press ?STATUS? 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press ?0? 5 times
3. (13x9) Press ?ANT? 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point? depending on where
12) When finishing up the 13x9 mode, to get additional ?grids? on the edges of the screen, press the PIP CH button
WARNING: YOU MUST DO THE FOLLOWING STEPS TO COMPLETE MAGIC FOCUS
INITIALIZATION!!! THERE HAVE BEEN MANY POSTS THAT PEOPLE HAVE HAD PROBLEMS
WITHOUT DOING THIS STEP BECAUSE THEY LOOSE MAGIC FOCUS!
17) Press PIP MODE and then PIP CH to initialize Magic Focus. The initialize operation starts and several
windows appear during this operation. It takes about 30 seconds or less.
18) When green dots appear, initialize operation is finished.
19) Turn power OFF.
21) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just
Oct 27, 2008 | Televison & Video
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba 65inch rear projection distorted video
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Aug 23, 2008 | Toshiba 65H84 65" Rear Projection HDTV
Convergence ICs
Well if you are not a repairman you should not do this kind of job yourself.
If you decide to service your TV, remember to keep it unplugged for one hour before working on it.
Check this link here to find sellers for the kit and illustrated procedures.
Here I am reporting convergence procedure from website above.:
" Manual Convergence for the Hitachi
a) ?STATUS? - Green
b) ?0? - Red
c) ?ANT? - Blue
3x3 - ?coarse?
7x5 - ?medium?
13x9 - ?fine?
19) Turn power OFF.
to make sure the magic focus still works (and that you did the last few steps properly)"
Perform full convergence procedure before replacing ICs.
To know if an IC has blown you should test the small fuse at the base of the IC.
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
17) Turn power OFF.
Jan 13, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B TV Logo
82 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
