Say failed to receive broadcast
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
