Star SWB7RBE Waffle Maker Logo
A
Anonymous Posted on Apr 26, 2014
Star waffle iron - Star SWB7RBE Waffle Maker
waffle maker specialist
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 06, 2016
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1556
Points
8
Need to replace the element or check for power getting to the element
3helpful
2answers
Owners Manual for White-Westinghouse Waffle Maker model WWM2001
Westinghouse Waffle Iron Operating Instructions ' eHow
www.ehow.com > Home
To that end, Westinghouse offers an electrical waffle iron capable of cooking two waffles at a time. Follow all of the safety instructions in the owner's manual ...
Westinghouse Waffle Iron Manuals - Kitchen Appliances ...
kitchen.manualsonline.com > ... > Kitchen Appliance Westinghouse
Westinghouse Waffle Iron WST3010ZE. Westinghouse OWNER'S MANUAL 2-SLICE BELGIAN WAFFLE MAKER WST3010ZE. Pages: 0 Saves: 0. See Prices
Westinghouse Waffle Iron WST3010ZE User Guide ...
3answers
How long do i keep the waffle batter in
Shortly after closing the waffle iron it will start to steam, Watch when the steam stops and open the iron. The waffle should be golden brown.
After you get the hang if it you can adjust the cooking time for lighter or darker waffles. There are videos on Youtube that may help too.
Lost instruction manual
Instructions
How to Select a Waffle Iron
Determine what type of cooking you'll be doing. If you're planning on preparing one waffle at a time, for example, then the smallest model of waffle iron will be the best fit for you. On the other hand, if you plan on frequent entertaining, or if you have a larger family, you'll probably want to choose a deluxe model.
Decide on the type of waffle maker that you'd like to own. There are a number of these available, ranging from simple differences---round versus square, for example. Some feature removable cooking elements that can be replaced with others, such as grilled sandwich attachments.
Internationally Accredited Hospital Visit Now to Get a Healthy Life!
www.apollohospdelhi.com
Take the varying grades of quality available in waffle makers into account when choosing one. This point may seem obvious---choose the highest quality waffle iron, right? Not necessarily. If you plan to use your waffle maker on rare occasions, say, once every couple of months, then you won't need the highest quality available. Waffle making several times monthly, however, will warrant a sturdier model with thicker non-stick coating applications applied to the cooking elements.
Consider the cleanup aspects of each waffle iron that you're comparing. Some waffle irons feature removable cooking elements; this is a tremendous benefit when cleanup time comes around, as it is much easier to clean the grill elements separately than attached to the entire waffle iron.
5
Take brand into account when making a decision. Brands with a reputation for high quality are usually more expensive than lesser-known labels. However, this doesn't mean that an "unknown" brand can't produce a good product. When taking this aspect into consideration keep in mind the requirements that you need and purchase a waffle iron accordingly. Additionally, many celebrity chefs have endorsed cooking products---including waffle irons---which adds a little more cost to the product. Finding the company's non-endorsed model of waffle iron will mean the same quality at less cost.
The top heating element doesnot not heat up
Usually have to order a replacement part for the top handle if it will come off.
I have a swb7re waffle iron. What's the best way to clean it?
Hello, W/D here.
Not everyone will tell you this, but here's the best way. When you are finished with the waffle maker, the plates will be oily. That's good. Wipe down the outside of the appliance with mild soapy water, followed by clean water. Wipe down the plates with clean water only, just enough to remove any left over waffle material. Then, dry the plates with paper towels, or a soft cloth. You want to avoid detergent on the plates, as this strips the oil off which seasons the plates, making better waffles.
Best regards, --W/D--
I purchased a Star waffle maker in April and now it will not heat up who do I talk to about this problem?
Nearly all appliances that use high heat in their operation such as your waffle maker, coffee makers, toasters, use a thermal fuse to prevent fire. Unfortunately, these fuses are all coming from China and are very poorly made. Additionally, they are mostly welded to their mounts since the heat to which they are exposed is too high for soldering or fuse holders and are not user replaceable.
You will need to ship back your waffle maker to the mfr. for repair and you should have plenty of time left on your warranty.
Contact the manufacturer for return instructions:
Star Manufacturing International
23helpful
2answers
How does the ready light work
WHEN THE LIGHT GOES OFF THE PLATES ARE HOT . so the light must be off to add your mix . then time ...... most waffles are done in 2 to 3 mins and your done remove waffle but dont add more batter untill the light is off if this answer helped please rate it 3 or 4 stars , this high rateing will help keep me in the paid answer department thank you
3answers
Waffles stick to both sides of iron
Lightly oil iron prior to heating it up. Use 2 Tablespons of oil in recipe.
1helpful
3answers
Waffle iron gets to hot -waffles stick
before you make your 1st waffle, spray it really good on top and bottom plate with PAM spray, once at the beginning is all it should take- good luck!
1helpful
Star Waffle maker tripes gfi when plugged in
no , wet control board , you will need it to dry out for a day first . place near a heater outlet or in the sunlight for a day or two ..... should be fine ...... please rate this answer i need it to "get my wings"
Top Star Kitchen Appliances - Others Experts
Paul Carew
john h
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
