Question about Averatec D1002UHCE-1 All-In-One Intel Desktop PC - Intel Core 2 Duo E4600 2.4GHz, 2GB, 320GB, DVDRW
Connect to tv - Averatec D1002UHCE-1 All-In-One Intel Desktop PC - Intel Core 2 Duo E4600 2.4GHz, 2GB, 320GB, DVDRW
Is this possible to connect the internet
Mostly only a SMART tv will connect to the internet. The instruction book will tell you more. The presence of an RJ45 socket should indicate possible internet capability.
Some tv top boxes will provide limited internet connectivity for older tv's for the purpose of catch-up tv and internet only tv channels.
Most tv sets can be linked to a desktop or laptop computer to provide full internet coverage on a large screen.
How do I change source resolution on my TV?
connecting PC to Tv through VGA - Tom's Guide
www.tomsguide.com/answers/id-1891563/connecting-vga.html
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Connecting my Plasma to my PC via the VGA port. - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Ensure that the VGA cable is working properly using other methods. Perhaps .... I am trying to connect my pc with my samsung tv. .... I'm very sorry to hear that has happened, and I apologize for any inconvenience this may have caused you. Connection between Dell laptop and Samsung TV
Jun 11, 2015
How to connect computer to tv with sound and picture?
Jun 5, 2015
PC Audio won't play through connected Samsung LCD TV
Jun 4, 2015
Connecting computer to TV
Jan 18, 2008
More results from www.cnet.com
My custom built PC will not connect to my TV via VGA cable ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Jun 28, 2013 - 5 posts - ‎2 authors
Trying to connect my PC to my TV using HDMI cable TV displays no signal PC LENOVO V570. I can connect to my other TV and works without problems..
Some TV's have to be off before you connect the HDMI cable to the computer. Try connecting the cable that way. Computer on --tv off--connect cable-- turn tv on.
2answers
My xperia m2 keeps saying connected to pc when connected to my tv trying to view photos
If you're connecting to your TV via a USB cable, then your phone can't differentiate between a TV usb connection and a PC usb connection.
Either way, when you connect it, it's basically just hosting its files to whichever device you're connecting it to.
Is your TV a smart TV? If so, there should be some way to access files on your phone, via the menu screen of the TV.
Need to connect my tv to the internet
Wifi dongle will available for TVs. If you had USB port on TV,connect that dongle on that and access internet.
2answers
Connect laptop to tv
To connect a laptop with a Sanyo TV, the TV must have VGA cable connection. VGA cable picture
If the TV is not equipped with a VGA cable, it can not be be a laptop and a TV connection.
1helpful
When I turn sony kdl32m4000 on, green power light comes on but
I understand that your TV is turning ON but you're not bale to view the videos on the TV screen. If the TV is connected to a wall outlet through a Surge protector please disconnect the connection through the Surge protector and try connecting the TV to a working wall outlet and check if that helps. Please check the connection between the TV and the connected device. Please try using a different device and check if that helps. This is to check whether the issue is with the TV or the connected device. Please try to explain the issue as much as you can next time. What are the video sources connected to the TV? Does this issue occur with the TV when connected to other devices? How did you connect the videos sources to the TV? Which connection are you using to connect the devices to the TV? You TV doesn't support 1080p resolution, so please check whether the connected device is giving output in 1080p resolution. If the issue still persists service of the TV is recommended.
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
2helpful
Connection problem with Denon 589 and direct tv
Averatec D1002UHCE-1 All-In-One Intel Desktop PC - Intel Core 2 Duo E4600 2.4GHz, 2GB, 320GB, DVDRW Logo
Top Averatec Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
