SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
SOURCE: KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. This model is manufactured by Whirlpool, so maybe you can locate your model's failure codes.
http://www.repairclinic.com/0078.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: Kenmore Elite Oasis error code F41
I don't see this code often although I can steer you in a good direction, F41 to F47 is error codes for dual motor problems on oasis.
SOURCE: Kenmore Elite Oasis Electric Dryer, Model #110.6708*, 6709*
Hi, my Kenmore Oasis Elite electric dryer has a poor fitting lint screen which allows for a large build up of lint in the bottom of the motor housing. This lint has also become blackened as if exposed to high heat. Some electric wires also show evidence of the plastic coating turning black and over heating. I get the feeling this unit is a fire hazzard. Model # C6704 A few days ago there was a distinct odour of electrical burning. This unit was purchased new in Dec. 08. Anyone else have this experience?
SOURCE: need to disassemble a kenmore elite oasis dryer
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
The AF error code for Kenmore Elite Oasis dryers with model numbers 11067032601, 11067042601, W10035200, 11067032600, and 11067042600 indicates that the dryer is experiencing an airflow problem. The Kenmore Elite Oasis owner's manual recommends four troubleshooting solutions to an airflow problem: clean the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Read more: Error Codes on Kenmore Dryers ' eHow.com http://www.ehow.com/list_7192588_error-codes-kenmore-dryers.html#ixzz1MuOgWsZC
it is found also on this link above by clicking the link if you have any further questions please message me back and your dryer should be dlinted at least once per year to avoid dryer breakdown you can also see how to dlint your dryer by clicking this tip that I wrote http://www.fixya.com/support/r8732702-prolong_life_dryer
I await your reply if you have any further questions Thanks Rick
