Question about Polaroid TLA-01511C 15 in. LCD Television
N POLAROID MODEL TDAC-02212 WIRING DIAGRAM
WHERE CAN I LOCATE THE POWER SUPPLY FUSE?
1 Related Answer
SD Tech
SD Tech
  • 14553 Answers
SOURCE: polaroid tdac-02212 remote quit working
should be under warranty but the remote itself can be tested by any shop--also some digital cameras when remote pointed at them in a dim room will react on their display screen with a flash when remote pointed at camera and buttons pressed on the remote.
Posted on May 22, 2012
Polaroid TDAC-02212 will not turn on. The red light is on and turns to blue momentarily when the power button is pushed. The screen will flash a little then back to off, with the red stand by light.
It may fix it with a new power supply but personally I'd recycle it...that wasn't a good set when it was new, lots of issues, Ive personally never seen a good Polaroid TV, they should have stuck to cameras as they were great back in the day.
Dec 10, 2017 | Polaroid Televison & Video
TDAC-02212. Why does it turn off with no warning message?
You probably have failing capacitors in the power supply. Or the panel itself is failing. The capicotr fix isnt too bad but if the panel is failing its no good.
Aug 03, 2015 | Polaroid Televison & Video
Where can I find a manual for polaroid 22" tv/dvd #TDAC -02212?
http://tv.manualsonline.com/manuals/mfg/polaroid/tda03211c.html
May be suitable for your model; it is nearly identical.
Also, try contacting the maker directly.
Dec 11, 2014 | Polaroid Televison & Video
We have a 22" Polaroid flat screen combo TV model #TDAC-02212 and the remote IERC03 does not work. Can I get another remote - the TV works with the built-in controls.
Dear Colleen,
Yes You Can, Try Typing "TDAC-02212 Remote" In The Amazon Search Engine. About $40 To $45 Bucks. It Should Come With A Manual On How To Program It To Your TV.
Sep 16, 2014 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
Service manual schematics
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 07, 2014 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
Missing part
I thought the same with mine but the little square part you looking for is in a piece of the styrofoam
Dec 29, 2012 | Polaroid 22 Class 720p 60hz LCD HDTV/DVD...
Wrong region
You maybe able to get a region free code from one of these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Dec 25, 2012 | Polaroid 22 Class 720p 60hz LCD HDTV/DVD...
Polaroid tdac-02212 remote quit working
May 21, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid TLA-01511C 15 in. LCD Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
