Canon PIXMA iP4200 InkJet Photo Printer Logo
Question about Canon PIXMA iP4200 InkJet Photo Printer
New How to fix Canon iP7240 1414 Printer Error
4answers
My MG 5765 will not recognise ink cartridges original canon please help.
Canon Printer Support Phone Number for Canon Printer Technical Support Services. Connect Canon Printer Customer Support Experts for Canon Wireless Printer Drivers Installation and Repair Canon Printers, Setup Canon Printer, Fix Canon printer Errors Message by Canon Printer Customer care service Number.
Canon Pixma Printer Support USA Canon Printer Support
I have canon 3600 printer that has b200 error how do I fix?
Printer failures are quite common among users. There can be Canon Printer Error B200 error for 2 or 4+ cartridge. The dreadful Canon b200 error can mean a lot many obstacles that can end up confusing the user in no time.
If you do not fix the Canon printer error b200 perfectly, there can be a want to buy a new printer altogether. To circumvent such expense, choose the problem the moment it arises.
6 Right steps to Resolve Canon Printer Error B200:-
1. Printer Driver-You should not ignore the notification to update the driver of your Printer.
2. Cartridge Related Issues-It may be possible that the reason behind Canon printer error b200 is the cartridge issue.
3. Blocked Nozzles-Blocked nozzles could be the main reason behind Canon error b200.
4. Tank Holder-Maybe you are facing the issue just because of a damaged Tank holder.
5. Check for any Stuck Paper-Open the print head of the printer and check if there is any piece of paper that got stuck inside it.
If the problem continues, check this blog or call Canon Printer support services or a Printer Support to stop more printer damage the number is in this blog- Canon Printer Error B200
2answers
Can you help me fixx error 1403 on canon printer
Canon Printer Error Code 1403 means that there is a problem with the printhead. The error can be evidence of the cartridge error. The printer's cartridge is defective or broken completely, this problem is what you get. At points, the cartridge isn't placed correctly. The objects click when it sites in their place. But if nothing like this is the situation, then you must plan to remove the cartridges with new ones or older ones which are working. Canon Printer Error Code 1403 occurs due to the inaccurate position of the printhead.
Want to fix the problem of Canon Printer Error 1403? Just follow the steps which are written on the blog to Canon Printer Error 1403. We give online help for Any problem in Canon Printers Errors.
Follow Blog to Fix Error 1403
Video Solution:
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
1helpful
5answers
How to solve canon printer mp280 error code 5011 ?
Was afraid this was the error that led me to toss a printer before. But after a quick search, found the following suggested fix for a potential registry problem. Problem with Windows Canon Mp280 Error 5011
Hope that does it.
I just install new CANON Pixma MX870 and got error 5011 message on display... I am able to print from computer, but copy and scan functions did not work. Turning power off and back on reset the alarm, but...
According to this forum post, it sounds like a hardware problem.
It is possible that the scanning mechanism is broken as copy and scanning both require the same technology.
Error Code 5011
Clive
Clive
old marine
old marine
