Tablets & eReaders Logo
A
Anonymous Posted on Apr 26, 2014
What does android.process.acore has stopped on my cnm9.7tablet mean, and how do i fix?
My pre installed browser no longer works and it now has japanese writing instead of browser underneath anthe message "unfortunately android.process.acore has stopped" keeps popping up, I've done the factory reset as instructed by cnm official site and all that's changed is all my apps etc are gone what do I do to repair?
5 Related Answers
Anonymous
  • 94 Answers
  • Posted on Mar 07, 2011
SOURCE: android.process.acore keeps showing up and
its a bug that pops up occasionally.if it happens when you open up when you open an app,create shortcut for the app on your home screen and itll work without error. a quick restart should fix it if its popping up unprompted
if all it else fails you may need to reflash a fresh rom onto your tablet
iiiears
  • 14 Answers
  • Posted on Apr 08, 2011
SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It came time to part with my review unit of the G1 (Thanks T-Mobile!) and send the phone back to its rightful owner. But what about all the personal info on the phone? The apps, texts, e-mails, AIMs and all that jazz? A quick search of AndroidForums.com turned up an easy way of restoring your G1 to factory settings:
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1.
Now all you have to do is pop open that pretty QWERTY keyboard and there are several keyboard shortcuts you can use to accomplish what you want to do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory settings. I'm sure the soft reboot could be helpful too, should you run into problems a troubled application may have caused. We didn't try the other 2 options so use at your own risk.
By the way, I couldn't live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile service plan. I'm still a loyal Verizon customer and will simply have to keep both plans... but I NEEDED the G1. So basically, you can expect the application reviews and insight you've gotten at phandroid.com to cotinue since we've got our very own device now!
[Via Android Forums]
Anonymous
  • 37 Answers
  • Posted on Jan 02, 2012
SOURCE: android tablet keeps getting error when trying to connect to the net. process com.andriod.browser has stopped unexpectedly.
Personally I'd flash it. I think you've got something corrupted in your system and its being triggered when you attempt to access the browser. Alternatively you can try downloading a different browser (http://www.4shared.com/android/ki088UbS/Dolphin_Browser_v200.htm) click download now wait the 20 seconds and an apk will show up for you to install. You will have to set your reader to accept outside downloads its in settings. Yea other than that do a full flash. Go to the support section of the cruz website and you'll be following the process for upgrading the firmware.
good luck
Anonymous
  • 274 Answers
  • Posted on Feb 08, 2012
SOURCE: my pandigital keep makeing me forceclose evrythingand i cant do nothing
It may the processor problem. or reinstall it and see.
Another method is to contact the supplier for help if you could not fix it.
Android 4.0 Tablet PC
Jim Dowell
  • 345 Answers
  • Posted on Dec 20, 2012
SOURCE: have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Everytime I swipe my 9" Polaroid tablet It tells me "Unfortunately, c?mara has stopped working" How do I stop this and how do I get the c?mara to work on it?
Unfortunately, Launcher has stopped - Android Forums at ...
forums.androidcentral.com/.../357082-unfortunately-launcher-has-stopp...
Jan 26, 2014 - 25 posts - ‎20 authors
Ilze C likes this. ... My husband has faster reflexes than me & managed to hit the app... This seems to happen to my HD7 every time I download an app but by .... open and a message pop up says unfortunately launcher3 has stop. i can't ... or Korean and then help me to solve the launcher stop working error ... How to Fix: Unfortunately, the process android.process ...
Jan 14, 2013
Unfortunately, the process com.google.process.gapps has ...
Dec 26, 2012
More results from forums.androidcentral.com
Missing: polaroid ‎mara
Fix for "android.process.acore" error on my tablet - YouTube
How do i fixandroid.process.acore
http://androidforums.com/threads/how-to-solve-error-unfortunately-the-process-android-process-acore-has-stopped.854534/
Scroll to the bottom and try the solutions in the green box.
The solution on the top is drastic and I wouldn't advise it unless all else fails.
1helpful
I keep getting a report box android process acore has stopped
Look at the green box at the bottom first and try that.
The factory data wipe/reset on the top should only be tried of all else fails.
My tablet is saying process android.process.acore has stopped working
You may have too many apps open in the background and have used all existing memory. Try turning of the tablet and back on.
I have a galaxy pro tab 10.1 that keeps rep the same error msg. ( unfortunately the process android, process.acore has stopped) and I can't do anything , I press OK and it goes away only to come right back...
I would recommend following the steps in the below link. It has detail information on how to fix this issue. Mine was same as you and it fixed. Though I lost a few apps and contacts. But did have a back up in my SD card and re installed them. Watch out and test your phone when installing the apps one by one and you could narrow down the culprit.
Force close error or process stops unexpectedly Android
Good luck and Merry Christmas.
Android.process.acore
Go into Settings/Applications/All and find Google Services Framework and clear the cache (if any) and clear data.
Disable DRM Protected Content Storage and Media Storage in your Apps list.
Or if either of those fails, uninstall latest update [until you get to the latest properly working update] or factory reset
1helpful
Have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
Why viewsonic viewpad 7e android process won't work?
if you're using a custom ROM re-flash GAPPS. Otherwise try to factory reset
1helpful
Generic A13-MID 1.2GHz 512MB 4GB 7
Unfortunately, the process android. Process. Acore has stopped how to fix it ls
Top Android Tablets & eReaders Experts
Alison Lofts
Alison Lofts
August Brown
August Brown
Antonios
Antonios
Are you an Android Tablet and eReader Expert? Answer questions, earn points and help others
