Question about Lenovo 3000 N500 Notebook
Lenovo care button
Where is it found
2 Related Answers
Anonymous
  • 21 Answers
SOURCE: where can i find lenovo care button on my keybord?
Are you talking about the ThinkVantage button? This is usually the blue button labeled "ThinkVantage" on the upper left of the keyboard. Right after the media or other buttons. On my T61 the upper left has the Esc key, 3 speaker buttons (mute, volume down and volume up) and then the blue rectangular ThinkVantage button.
Posted on Apr 07, 2009
Anonymous
  • 80 Answers
SOURCE: lenovo care button not working
You will need to download the drivers and software from the lenovo support site for vista
The link below points to the software/drivers for your laptop
Check the back of your laptop for the type number and select accordingly for the drivers.
http://www-307.ibm.com/pc/support/site.wss/product.do?template=/product.do?template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&sitestyle=lenovo&brandind=10&familyind=370177&machineind=0&modelind=0&partnumberind=0&subcategoryind=0&doctypeind=100&doccategoryind=0&operatingsystemind=49979&validate=true
Posted on May 29, 2009
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
My notepad says operation not found
Does it say "operation not found", or "operating system not found"? Big difference...
Jan 21, 2013 | Samsung NC110 Netbook
Want to delete addresses in recently found folder
Click on-Where to-Favourites-All Favourites-Click on the Address you want to delete,click on Edit,it then says Delete,touch Delete,it then asks you if you want to Delete or not,hope this helps you.
Oct 23, 2009 | Garmin nuvi 255W GPS Receiver
Can't get rid of bloodhound pdf 8 and now I can't get into my user profile
You are going to have to get your hard drive wiped and windows re-installed then you will be able to have your computer up and running again!
May 07, 2009 | Computers & Internet
Unlocking T-mobile forn
i found a simple way to unlock..a comapny i found where i found unlock instruction http://www.unlock-zone.com/ reach here u may get assistance
Apr 09, 2009 | T-Mobile Motorola Razor V3 Custom Cell...
Blinks twice pause blinks 4 times
SYMPTOMS
Dead or Shutdown symptoms.
RESOLUTION
Dead symptom reported to be caused by the following:
1. Dead.
Found Q601 & Q602 shorted, R615 open, and IC600 on the A Board were the cause of the symptom.
2. Dead.
Found D614, Zener diode, on B+ line was shorted.
3. Set shutdown and the standby LED blinks 3 then 5 times.
Found 200v line was low. Disconnected CN706 on the C Board and found 200v now
present on CN706/pin 7.
Found: IC702 (C board) shorted the 200 volt line.
HQ Comments: C541 on the A Board could become defective if the 200v line is shorted since
the polarity on the capacitor will become reversed. R553 fuse resistor could also be opened
on the A Board.
4. Error code of 4 blinks .
Dead set press power button you hear the relay and you see red led flash 3 times and stops? Has no HV or other action. Tech removed the back as no 200 volt supply, did unplug CN706 and now has 200volts. Tech did remove the IC702 and same it comes up so needs this IC.
5. Dead. 5 blinks then 3 blinks. Found shorted Damper diode D504. Q502 has a built in damper, as well.
6. The TV does not turn On and the LED flashers 9 times.
Found one side of R610 open on the Base of Q690 on the A board.
7. Dead, 9 flashes, Q606
Would not start when cold, has stand by 5 but relay never energize.
No response from front panel or remote controls.
9 blinks is not in service manual.
Found Q606 (Zero Det.), on the A Board, had no soldered on the collector
of the transistor causing an intermittent connection.
Soldered the collector of Q606 and set returned to operation.
HQ Comments: Also refer to E30968554.
8. Dead. 5 blinks or 3 blinks
Found on the A Board D611 in the Power Supply open, and Hor. Output Q502 shorted.
9. Found Power Supply components D611 shorted causing Q600, Q601, and R615
to fail on the A Board.
10. No picture or sound. Standby flashes.
Found Q512 (Pin Out) shorted. on the A Board.
11. Dead. No sound or picture.
Found the FBT and Q502 were shorted, and R615 open on the A Board.
12. Dead
No power, Stand by light flashes 4 times.
Found T604 and IC601, replaced.
Found D611 on the A Board was the cause of the symptom.
13. Dead.
Found D534 shorted on the A Board.
14. Shutdown 4 Blinks.
Replacing R595, OCP Latch Q532 on the A Board, fixed the set.
PN 1-247-891-00, 330K 1/4 watt.
15. Unit shuts down after 15 mins.
Immediate shutdown - sometimes it give a 3 blink, sometimes nothing.
Found R595 (330K) was open located in the Q532 OCP Latch circuit.
R595 P/N 124789100 330k 1/4w
16. Won't power up. LED Blinks 4 times, B+ is very low
B+ is at 49V, +15/-15 only coming up to about 1 volt.
Wth Hor Out disconnected B+ only comes up to 50v.
17. Intermittently does not turn on
Found a intermittent C633 on pin # 3 of IC600.
C663 P/N 113647911 Film cap .001uf 100v
Billy
If you need the service manual contact me at:[email protected]
Jan 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do i reset the Coby MP-C781 MP3 Player. if i cant my problem is i can't see the menu choices after i pick nav or sys and a hidden file called found.0000, found.0001, found.0002 please help me
please help me
Dec 03, 2007 | Coby MP-C781 MP3 Player
Lenovo 3000 N500 Notebook Logo
181 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
